j2lstaples Posted November 15, 2023 Posted November 15, 2023 I currently use this command to change the layer's (lay) viewport override color (col) to grey (252). (command-s "vplayer" "c" col lay "" "") Doing this iteratively is so time-consuming that I've been trying to find other ways to do it. ActiveX doesn't really have a method for doing this. Quote
BIGAL Posted November 16, 2023 Posted November 16, 2023 You can get all the viewports in a layout, then in a loop change them, a warning if I remember correct the last viewport is PSPACE. So repeat for (- (sslength ss) 1) (setq ss (SSGET "X" '((0 . "VIEWPORTS")(cons 410 (getvar 'ctab)))))) Quote
