BLOACH85 Posted February 24, 2009 Author Posted February 24, 2009 no i wrote the code but the way that you put it i was kind confused i allready have a couple of action tiles in my in/out for example (action_tile "cancel" "(done_dialog)(setq UserClick nil) ") This is what you were saying right? Im not knew to lisp but i am kinda fresh to dcl. Quote
The Buzzard Posted February 24, 2009 Posted February 24, 2009 Action tiles take the information from the dialog place it in a variable to be used someplace within the program. The OK or accept action tile implements all the events to take place based on what input in the DCL was supplied. Quote
The Buzzard Posted February 24, 2009 Posted February 24, 2009 You can have an action tile in some cases for each button or toggle or whatever is in the DCL. Its a way to pass the information on thru the program. Quote
BLOACH85 Posted February 24, 2009 Author Posted February 24, 2009 now do i need this even if the image is just for display? Quote
The Buzzard Posted February 24, 2009 Posted February 24, 2009 Not at all. I was under the impression you were still changing images. If you are changing images, Then yes you will need it. Quote
BLOACH85 Posted February 24, 2009 Author Posted February 24, 2009 Ok see thats what was confusing me. No this is just for display purposes. Quote
The Buzzard Posted February 24, 2009 Posted February 24, 2009 Then you need this in the DCL to have a place to put the image. : image { key = "im1"; height = 7; aspect_ratio = 1.5; color = 0; allow_accept = true; } And you will need this in the lisp file to set the image to the tile in your DCL (setq w (dimx_tile "im1") h (dimy_tile "im1")) (start_image "im1") (slide_image 0 0 w h "Name of your slide image goes here") (end_image) And finally you need the slide Thats it. Quote
Lee Mac Posted February 24, 2009 Posted February 24, 2009 Sorry to interrupt this thread, but just as a tip for creating slide (SLD) images: Create a Viewport in any layout and dimension it to a ratio of 2:3, i.e two unit height to 3 unit width. -- I made mine 400x600. Draw your desired image in model space to any dimensions. Go to the layout and zoom extents. Whilst still in the Viewport, type mslide in the command prompt. Select a name and location for your slide image. This should produce the best possible size for your slide image. Quote
Lee Mac Posted February 24, 2009 Posted February 24, 2009 And another thing - when you use the slide image, you can first fill the background colour of the image tile to a different colour to fit with the slide image. I used something like this: (defun imgupd (img key) (start_image key) (fill_image 0 0 (dimx_tile key) (dimy_tile key) -15) (slide_image 0 0 (dimx_tile key) (dimy_tile key) img) (end_image)) Where -15 colour is the dialog box backing colour. Quote
The Buzzard Posted February 24, 2009 Posted February 24, 2009 Thats great way to make slides. Thank you, Lee MacDialog Quote
BLOACH85 Posted February 25, 2009 Author Posted February 25, 2009 Hey i got My slide to insert but as soon as i press the accept (ok) button the slide goes away. Why is this? Quote
