phjlc Posted November 14, 2023 Posted November 14, 2023 (edited) Hi again guys, so I have this code : (setq table (ssget "x" (list '(0 . "INSERT") '(8 . "___OIS-HL-SELECTION!")))) (setq lp (- (sslength table) 1)) (repeat (sslength table) (progn (setq c (strcat c " " (vla-get-textstring(nth 0 (vlax-invoke (vlax-ename->vla-object (ssname table lp)) 'getattributes))))) (setq d (strcat d "/" (vla-get-textstring(nth 0 (vlax-invoke (vlax-ename->vla-object (ssname table lp)) 'getattributes))))) (setq lp (- lp 1)) ) ) (setq c (substr c 2 (strlen c))) (setq d (substr d 2 (strlen d))) (initget c) (setq a (getkword (strcat "Callout Selection : ["d"]"))) But if you see in the very last is PV02, is there a way to change the order of ssget so* that PV02 is next to BA01b, [this is because I create the block PV02 last which indicate the order, and if i redo all of the other blocks after BA01b it will remove the field already reference to other blocks after BA01b] Edited November 14, 2023 by phjlc Quote
Steven P Posted November 14, 2023 Posted November 14, 2023 Not sure if you can order the selection set itself, You could do a while loop, extract each entity name into a separate list in turn, order that list and then another loop to create or re-create the selection set using ssadd with that list Quote
Lee Mac Posted November 14, 2023 Posted November 14, 2023 Construct a list within the repeat loop which may then be sorted using vl-sort - do not rely on the order of entities in a selection set. Quote
BIGAL Posted November 15, 2023 Posted November 15, 2023 Like Lee a SORT of the list will do just that be alphabetical. Trying to re-arrange order only would be very difficult. This makes selections for you based on a list, a hidden feature is it returns the button picked as a string but also the "BUT" variable holds a value of the button selected so you can get an answer from a second list as I think you want, the desired value. (nth (- but 1) lst2)). You can use it in any code with just a couple of lines of code. Multi radio buttons.lspFetching info... Quote
