jackcxq Posted November 10, 2023 Share Posted November 10, 2023 Regarding the stretching and alignment of coordinate points, I have imported a group of coordinate points using CAD. I would like to stretch these coordinate points to match the dimensions of reference four edges, while aligning them with the points on these four edges. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted November 10, 2023 Share Posted November 10, 2023 Not exactly sure what you're asking, but have you tried making a block out of the points? You can rotate the block as needed or use the ALIGN command. You can adjust the X and Y scales separately (make sure 'Scale uniformly' is turned off). If you need to stretch one end and not the other, as your photo seems to suggest, that will take more thought. How does that even happen?? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 10, 2023 Share Posted November 10, 2023 What does ALIGN do pick pt1 pick reference point1, pick pt2 and so on. It allows rescale and rotation. 1 Quote Link to comment Share on other sites More sharing options...
jackcxq Posted November 11, 2023 Author Share Posted November 11, 2023 19 hours ago, CyberAngel said: 不太确定你在问什么,但是你是否尝试过将这些点作为一个块?您可以根据需要旋转块或使用 ALIGN 命令。您可以分别调整 X 和 Y 比例(确保“均匀缩放”已关闭)。 如果您需要拉伸一端而不是另一端,正如您的照片所示,则需要更多考虑。怎么会发生这种事? Alright, let me rephrase the question. I want to align the red coordinate point exactly with the white lines. However, as seen in the image, the red coordinate point rectangle is not the same size as the white line rectangle. Quote Link to comment Share on other sites More sharing options...
jackcxq Posted November 11, 2023 Author Share Posted November 11, 2023 9 hours ago, BIGAL said: ALIGN 的作用是什么 pick pt1 pick reference point1, pick pt2 等等。它允许重新缩放和旋转。 Yes,I have used its. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 11, 2023 Share Posted November 11, 2023 Post a dwg image is not clear. Quote Link to comment Share on other sites More sharing options...
