Alternatives to Burst
AutoCAD LT 23 doesn't have the burst command and doesn't use autolisp. Does anyone know of a workaround to explode blocks and retain their information, preferably as text and not attributes?
I'll be out of pocket for a little while but will acknowledge any replies when I get back.
Thanks
LT 2024 supports Lisp with limitations, yes it can bite you at times with some stuff missing.
  • 3 weeks later...
On 11/6/2023 at 2:52 PM, Steven P said:
LT 23 has some LISPs or is it LT24 where they started using them, in which case you could try: http://lee-mac.com/upgradedburst.html, however this was written for full CAD and not the limited LISP that LT has now
Can confirm, this seems to work in LT24! Thanks!
