Gascon Posted November 5, 2023 Share Posted November 5, 2023 Hello everyone, I have started using Auto CAD for the first time ever today. I am trying to draw something. I am trying to create a diameter dimension for a circle. However, instead of creating a line that crosses the entire circle to signify diameter, my AutoCAD only creates half a line. This can be confusing for the person who will make my design as they might think that the radius of the circle is for example 3 instead of the diameter being 3. I have attached a screenshot. If you can advise how to fix this I would appreciate it. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 6, 2023 Share Posted November 6, 2023 Check your dimstyle, make sure the left and right extensions are ticked on. What does a Horizontal dim look like ? Quote Link to comment Share on other sites More sharing options...
Gascon Posted November 6, 2023 Author Share Posted November 6, 2023 1 hour ago, BIGAL said: Check your dimstyle, make sure the left and right extensions are ticked on. What does a Horizontal dim look like ? I checked and they're on. If I use a diameter dim it will only draw half a line no matter where in the circle or at which direction I put it. I tried and could draw a full diameter line using aligned dim. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 6, 2023 Share Posted November 6, 2023 Type Diameter Dimension tool measures the diameter of an arc or circle. To create a Diameter dimension, click object 1 (i.e. - the circle) then click point 2 (on outside of circle) to create the dimension line. 1 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 6, 2023 Share Posted November 6, 2023 You'll need to set that up in your Dimension Style. Check through the FIT category. See the "Draw dim line between ext lines" (DIMTOFL sysvar) and check it, test some of the other options as well. 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 6, 2023 Share Posted November 6, 2023 Need your dwg to test. 1 Quote Link to comment Share on other sites More sharing options...
Gascon Posted November 7, 2023 Author Share Posted November 7, 2023 Hi Someone on another forum advised me to use an aligned dim on the circle and add the pi symbol manually and I did that for now. I feel like this is a bug either on my system or in my app. I have attached my DWG file. Thanks. Plexiglass laser cut black - 1st Release Candidate.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 7, 2023 Share Posted November 7, 2023 (edited) Maybe something like this if want on an angle then can add a rotation. CDIM45 or C45 ? (defun c:cdim ( / ent oldsnap entg rad cpt pt1 pt2) (setq ent (entsel "\nPick a circle")) (setq oldsnap (getvar 'osmode)) (setvar 'osmode 0) (setq entg (entget (car ent))) (setq rad (cdr (assoc 40 entg))) (setq cpt (cdr (assoc 10 entg))) (setq pt1 (mapcar '+ cpt (list rad 0.0 0.0))) (setq pt2 (mapcar '+ cpt (list (- rad) 0 0.0))) (command "dimaligned" pt1 pt2 cpt "")) (setvar 'osmode oldsnap) (princ) ) Edited November 7, 2023 by BIGAL Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 7, 2023 Share Posted November 7, 2023 All you need to do is create the correct Dimstyle. Plexiglass laser cut black - Modified Dim Style.dwg Quote Link to comment Share on other sites More sharing options...
