How to select the object before using (vlax-for x (vla-get-activeselectionset
(setq Pr_PolySelection (ssget))
(repeat (sslength Pr_PolySelection)
		(setq poly_Ent (ssname Pr_PolySelection 0))
		(setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))
		(vla-clear (vla-get-activeselectionset *AcadDoc*))
		(vl-cmdf "_.pselect" poly_Ent "") ;<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
		(setq Add nil Add (ssadd))
		(vlax-for x (vla-get-activeselectionset *AcadDoc*)
			(vla-getboundingbox x 'P1 'P2)
			(setq P1 (vlax-safearray->list P1))
			(setq P2 (vlax-safearray->list P2))
			(and (setq Temp (ssget "_C" (trans (list (car P1) (cadr P2) 0.) 0 1) (trans (list (car P2) (cadr P1) 0.) 0 1) '((0 . "LWPOLYLINE"))))
				(ssdel poly_Ent Add)
Any idea how to select   poly_Ent   before  (vlax-for x (vla-get-activeselectionset
without using    (vl-cmdf "_.pselect" poly_Ent "")  because it slow the code too much
Edited by Engineer_Yasser
21 hours ago, Lee Mac said:
Why not just use (setq x (vlax-ename->vla-object poly_Ent)) ?
Thanks very much, it worked like a charm  😍🌹
Issue solved
"This is part of a Lisp to select touched polylines." Show say a dwg or image what is previous selection set. You can also do the repeat for items in a selection set much easier.
(repeat (setq K (sslength Pr_PolySelection))
(setq polyent (ssname ss (setq k (1- k))))
If I understand you want a single bounding box of selected objects ? You seem to be doubling up on what your asking for.
Edited by BIGAL
Good idea, I used it in the code, it's faster, Thanks  👍
