shell command
mousho
hi friends
i have a sort problem that stop work for me and i try everyhing already and its not working
i'm trying to sort the txt file by the place of 8 letter in the file
(command "_.Shell" 	(strcat "sort /+8 <" "C:\Autocad Lisp\mpdlist.txt" ">" "C:\Autocad Lisp\newlist.txt"))
or
(command "_.Shell" 	(strcat "sort /+8 <" "C:\\Autocad Lisp\\mpdlist.txt" ">" "C:\\Autocad Lisp\\newlist.txt"))
few years ago it did work :(
mpdlist.txt
7 hours ago, mousho said:
hi friends
or
@mousho The 2nd option worked fine for me. It has to be the 2nd version because you MUST use the "\\" to create the single "\" in the actual shell command. Make sure the path exists and everything is spelled correctly. I used the following in my test:
(command "_.Shell" (strcat "sort /+8 <" "C:\\Temp\\mpdlist.txt" ">" "C:\\Temp\\newlist.txt"))
Results:
%%17410   1L=520          2  1    1398
%%17410   2L=747          2  1    1398
%%17410   3L=1198         2  1    1398
%%174 8   4L=954          2  1    1398
%%174 8   5L=520          2  1    1398
%%17410   6L=520         14 15  200399
%%17412   7L=747         14 15  200399
%%17412   8L=1198        14 15  200399
%%174 8   9L=954         14 15  200399
%%174 8  10L=520         14 15  200399
Edited by pkenewell
Results:
thx i found that there is a problem with the space in the folder name, the program dont know how to treat with space bar
@mousho I figured it out. You need to add embedded quotes into the path arguments using a double quote preceded with the backslash on each end of the parts (i.e. \"):
(command "_.Shell" (strcat "sort /+8 <" "\"C:\\Temp\\mpdlist.txt\"" ">" "\"C:\\Temp\\newlist.txt\""))
