The plines have to be parallel or else you will have 2 lines with different angles. Like devitg your request is not clear, has contradictions.
6 hours ago, devitg said:
@mik, please clear us.  at your after there are a line between the 2 points extended to  2 polys
from 2 point i need perpendicular line  between polyline
sorry i update for you
You can not have "from 2 point i need perpendicular line" it only occurs if the 2 points are in a perpendicular direction from 2 parallel lines. It's a geometry thing !
Thank you. How can I edit an attachment or delete it?
To edit your thread, select the ellipsis on the upper right of the post and then select edit.
I removed the file for you.
  • Thanks 1
