mik Posted November 1, 2023 Posted November 1, 2023 (edited) from https://www.cadtutor.net/forum/topic/66657-perpendicular-lines-from-many-points-to-a-polyline/page/2/ Can it create lines running perpendicular to two polylines? Edited November 2, 2023 by SLW210 Removed file per request. Quote
devitg Posted November 1, 2023 Posted November 1, 2023 (edited) On 11/1/2023 at 3:08 AM, mik said: from https://www.cadtutor.net/forum/topic/66657-perpendicular-lines-from-many-points-to-a-polyline/page/2/ Can it create lines running perpendicular to two polylines? @mik, please clear us. at your after there are a line between the 2 points extended to 2 polys Edited November 2, 2023 by SLW210 Removed File per request. 1 Quote
BIGAL Posted November 1, 2023 Posted November 1, 2023 The plines have to be parallel or else you will have 2 lines with different angles. Like devitg your request is not clear, has contradictions. 1 Quote
mik Posted November 2, 2023 Author Posted November 2, 2023 6 hours ago, devitg said: @mik, please clear us. at your after there are a line between the 2 points extended to 2 polys from 2 point i need perpendicular line between polyline Quote
mik Posted November 2, 2023 Author Posted November 2, 2023 1 hour ago, BIGAL said: The plines have to be parallel or else you will have 2 lines with different angles. Like devitg your request is not clear, has contradictions. sorry i update for you Quote
BIGAL Posted November 2, 2023 Posted November 2, 2023 You can not have "from 2 point i need perpendicular line" it only occurs if the 2 points are in a perpendicular direction from 2 parallel lines. It's a geometry thing ! Quote
mik Posted November 2, 2023 Author Posted November 2, 2023 Thank you. How can I edit an attachment or delete it? Quote
SLW210 Posted November 2, 2023 Posted November 2, 2023 To edit your thread, select the ellipsis on the upper right of the post and then select edit. I removed the file for you. 1 Quote
