Frogger Posted October 31, 2023 Posted October 31, 2023 The plines are there they are not showing in model space. Quote
SLW210 Posted November 1, 2023 Posted November 1, 2023 Without a .dwg all I could do is take some guesses. What have you done so far to solve this? Did you create the drawing with AutoCAD? Start with the layer color, visibility etc. Quote
Frogger Posted November 1, 2023 Author Posted November 1, 2023 I found the issue was the Engineer had not updated his AutoCAD. Problem was solved. Thanks for the reply. Quote
KayceeWhite Posted November 15, 2023 Posted November 15, 2023 Ensure the polyline layer is visible and unfrozen. If using viewports, check layer visibility within them. Zoom to extents and regenerate the drawing. Update graphics drivers if needed. Quote
