3arizona Posted October 30, 2023 Posted October 30, 2023 I found this lisp and got it to work, . The only problem is that i want it to filter for a certain block. Hope someone can help me out. thanks (defun C:COUNTATT(/ acapp acol acsp adoc atable attdata attitem atts blkdata blkname blkobj col column colwidth datalist en headers pt row sset swap tabledata tags total txtheight widths x) ;private function (defun sum-and-groupby-three (lst / groups res sum tmp) (while lst (setq tmp (car lst) sum (apply '+ (mapcar 'atoi (mapcar 'cdadr (setq res (vl-remove-if-not '(lambda (a) (and (eq (cdr (nth 0 a)) (cdr (nth 0 tmp))) (eq (cdr (nth 1 a)) (cdr (nth 1 tmp))) (eq (cdr (nth 2 a)) (cdr (nth 2 tmp))))) lst ) ) )) ) groups (cons (subst (cons "QTY" (itoa sum))(cadr tmp) tmp) groups) lst (vl-remove-if '(lambda (a) (member a res)) lst ) ) ) (reverse groups) ) ; main part ; (if (setq sset (ssget (list (cons 0 "INSERT") (cons 66 1)))) (progn (setq tabledata nil attdata nil attitem nil ) (while (setq en (ssname sset 0)) (setq blkobj (vlax-ename->vla-object en) blkname (vla-get-effectivename blkobj) ) (setq atts (vlax-invoke blkobj 'getattributes)) (foreach attobj atts (setq attitem (cons (vla-get-tagstring attobj) (vla-get-textstring attobj))) (setq attdata (cons attitem attdata)) ) (setq tabledata (cons (reverse attdata) tabledata)) (setq attdata nil attitem nil ) (ssdel en sset) ) (setq headers (mapcar 'car (car tabledata)) tags headers ) (setq tabledata (sum-and-groupby-three tabledata)) (setq tabledata (mapcar '(lambda (x) (mapcar 'cdr x) ) tabledata ) ) ;; sort by "A1" : (setq tabledata (vl-sort tabledata '(lambda(a b)(< (car a)(car b))))) (setq total 0) (foreach i datalist (setq total (+ total (cdr i)))) (initget 6) (setq txtheight (getreal "\nSpecify Text height for the table <48>:")) (cond ((not txtheight)(setq txtheight 48))) ;<-- text height as for as in your drawing (or adoc (setq adoc (vla-get-activedocument (setq acapp (vlax-get-acad-object))))) (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc)))) (setq acCol (vla-GetInterfaceObject acapp(strcat "AutoCAD.AcCmColor." (itoa(atoi(getvar "acadver")))))) (setq pt (getpoint "\nSpecify table location:")) (setq atable (vla-addtable acsp (vlax-3d-point pt) (+ 2 (length tabledata)) (length headers) (* txtheight 1.2) (* txtheight 20) ) ) (vla-put-regeneratetablesuppressed atable :vlax-true) ;; calculate column widths : (setq swap (append (list headers) tabledata) widths nil) (while (car swap) (setq column (mapcar 'car swap)) (setq colwidth (* 1.5 (apply 'max (mapcar 'strlen column))txtheight)) (setq widths (cons colwidth widths)) (setq swap (mapcar 'cdr swap))) (setq widths (reverse widths)) ;; set column widths (setq col 0) (foreach wid widths (vla-setcolumnwidth atable col wid) (setq col (1+ col)) ) (vla-put-horzcellmargin atable (* txtheight 0.5)) (vla-put-vertcellmargin atable (* txtheight 0.3)) (vla-setTextheight atable 1 txtheight) (vla-setTextheight atable 2 txtheight) (vla-setTextheight atable 4 txtheight) (vla-setText atable 0 0 "Panel Information") (vla-SetCellAlignment atable 0 0 acMiddleCenter) (vla-put-colorindex accol 2) (vla-setcellcontentcolor atable 0 0 accol) (setq col -1) (foreach descr headers (vla-setText atable 1 (setq col (1+ col)) descr) (vla-SetCellAlignment atable 1 col acMiddleCenter) (vla-setcellcontentcolor atable 1 col accol) ) (vla-put-colorindex accol 1) (setq row 2) (foreach record tabledata (setq col 0) (foreach item record (vla-setText atable row col item) (if (= 1 col) (vla-SetCellAlignment atable row col acMiddleCenter) (vla-SetCellAlignment atable row col acMiddleCenter) ) (vla-setcellcontentcolor atable row col accol) (setq col (1+ col)) ) (setq row (1+ row)) ) (vla-put-width atable (apply '+ widths)) (vla-put-height atable (* 1.2 (vla-get-rows atable)txtheight)) (vla-put-regeneratetablesuppressed atable :vlax-false) ) ) (if accol (vlax-release-object accol)) (if acapp (vlax-release-object acapp)) (princ) ) (prompt "\n\t---\tStart command with COUNTATT\t---\n") (prin1) (or (vl-load-com)) (princ) Quote
mhupp Posted October 30, 2023 Posted October 30, 2023 Update the ssget with the block name should do the trick (if (setq sset (ssget (list (cons 0 "INSERT") (cons 2 "BLOCK NAME") (cons 66 1)))) 1 1 Quote
j2lstaples Posted November 2, 2023 Posted November 2, 2023 What are you trying to filter for? by effective block name or just block name?? This would require a different operation. Quote
3arizona Posted November 17, 2023 Author Posted November 17, 2023 yes, i wanted to filter per block name. I appreciate your time. Thank you!! Quote
