LETS TRADE!!!!! Watchu got? Send me your CLEAN/ORGANIZED list/files and I’ll send mine.
* = I can’t live without it.
--My routine List--
bearings.lsp = annotates lines/surveyor units (not curves!!)
*fl.lsp = flip polyline
*J.lsp = join polylines (want one with pick first)
*len.lsp = total length of selected lines/poly lines/arcs/splines
lp.lsp = locate point to text (change text with dimscale)
lpx.lsp = same as lp (exports point to a .csv file in the same folder as .dwg)
*MdiTab17.arx = Adds open drawing tabs to your workspace
*num.lsp = auto number (would like it use current text style)
*numre.lsp = renumber selected text
*ob.lsp = offset both sides of line (want to have erase selected object default to no)
*ol.lsp = offset to current layer (want one to offset to current layer by selection)
*prec.lsp = change precision of numbers
*Renamer.lsp = adds prefix/suffix/or find and replace enhanced
*sqa.lsp = area to text ac.
*sqf.lsp = area to text s.f. (want one to prompt for area in ac./as well as s.f….s.y. may be nice)
*sum.lsp = adds #’s
*tc.lsp = tangent check
*txt2xyz.vlx = converts text to point with elevation/z value
*vpl.lsp = draws vport into paper space
*xe.vlx = changes properties of lines/xrefs through selection
--Routines I have, I would like replaced or modified--
1. sqf.lsp = area to text s.f. (want one to prompt for area in ac./as well as s.f….s.y. may be nice)
2. J.lsp = join poly lines (want one with pick first)
3. num.lsp = auto number (would like it to use current text style rather than specifying text height)
4. ol.lsp = offset to current layer (want one to offset to current layer by selection)
--Routine wish list--
1. multiline to text (for example I have a 24” rcp etc… multiline I want to label by selecting it)
2. change increment of all selected text by a specific value (for example raise all grade bubbles by 0.20 or reduce all selected lot #’s by 10)
3. ----ANY AWESOME ROUTINES YOU CAN’T LIVE WITHOUT
u r i i m u @ g m a i l . c o m (no spaces)
Anyone else got a headache after reading the above post ?
