Hi all
Could someone help me to create a lisp, that perform arithmetical operation - subtraction only on numerical data within Text/Mtext which may include Alphabetical Prefixes, please?
For example: The idea would be to click on the first text, than on  the second text and the second text replacing itself with the answer, So IL0.50 should become IL11.50 and IL1.00 should become IL-0.80
First Example:
CL12.00
IL0.50
Second example:
CL0.20
IL1.00
Thank you
This one is what you want by Lee I use it various programs regarding to strings with numbers. Example code at end.
;;-------------------=={ Parse Numbers }==--------------------;;`
;;  Parses a list of numerical values from a supplied string. ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  s - String to process                                     ;;
;;  Returns:  List of numerical values found in string.       ;;
(defun LM:ParseNumbers ( s )
    (lambda ( l )
      (read
        (strcat "("
          (vl-list->string
            (mapcar
              (function
                (lambda ( a b c )
                  (if
                    (or
                      (< 47 b 58)
                      (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
                      (and (= 46 b) (< 47 a 58) (< 47 c 58))
                    b 32
              (cons nil l) l (append (cdr l) (list nil))
    (vl-string->list s)
(defun c:wow ( / num1ent num2ent num1str num2str diff tstr)
  (setq num1ent (entget (car (entsel "\npick 1st text "))))
  (setq num1str (cdr (assoc 1 num1ent)))
  (setq num1 (car (LM:ParseNumbers num1str )))
  (setq num2ent (entget (car (entsel "\npick 2nd text"))))
  (setq num2str (cdr (assoc 1 num2ent)))
  (setq num2 (car (LM:ParseNumbers num2str )))
  (setq diff (- num1 num2))
  (setq tstr (strcat "IL " (rtos diff 2 2)))
  (entmod (subst (cons 1 tstr) (assoc 1 num2ent) num2ent))
(c:wow)
Edited by BIGAL
  • Thanks 1
;;  Arguments:                                                ;;
    (lambda ( l )
      (read
        (strcat "("
          (vl-list->string
            (mapcar
              (function
                (lambda ( a b c )
                  (if
                    (or
                      (< 47 b 58)
                    b 32
    (vl-string->list s)
(c:wow)
Thank you BIGAL, Just like I have imagined!  ;) wow
BIGAL, may I ask if we could tweak it slightly?
1) To Change the colour of the selected entities to the RGB colour (255, 0, 0)   -  basically so it could stand out.
2) It may be not only ''IL'' prefix, but also any other alphabets, for example WL or SL  - for some reason it replaces  WL1.00 to IL 1.00
Edited by pyou
I did not look at prefix so will need a code edit. will see what I can do.
  • Thanks 1
Thank you BIGAL
I have found the solution.
Edited by pyou
