Autocad LT 2023
I have a laptop and two external monitors. They worked fine, dragging documents from one to the other as expected. I been away and took my laptop with me. When I've returned home and connected everything up as normal, for some reason I now can't drag an autocad drawing from my laptop screen to the other screens. Other docs and files are fine, so it's reasonable to assume its an autocad LT issue. Any ideas?
I also can't display the properties on screen so, as an example, I have no way of clicking on a line I have drawn and determining the length, width or other details.
Ok, so the files are now moving between screens. I still can display properties on screen. Any help?
Seen this type of problem with dual screen between multi staff, screens are L->R others R->L. Stuff is gone.
Start with bring CAD back onto the primary display, then try properties. Then move back to other screen.
Check which screen is primary and secondary, using the windows interface.
