My wall lines are not visible
I previously saved a floor plan from ArchiCAD into a dwg file. I had another laptop with AutoCAD 2023 LT installed and I could open the file just fine . However on updating to a gaming laptop with AutoCAD 2024 LT installed, the wall showing the edges of the wall do not appear. Anybody have a solution on what I should do.
Can you post the drawing?
Just guesses without a drawing. What have you tried?
I don't know ArchiCad, are the walls just normal lines? In which case I would be looking at layers (on /off), scaling for dashed lines etc, or colours that make the lines vanish. I assume that they don't show on the screen and in plotting? Are the line types supported in LT2024, if you can convert them to continuous lines on layer 0 to see if they show up then?
If the lines show up OK in LT2023 then I suspect they are exported OK, you just can't see them. Can you still access the other laptop.... save the drawing as dwg, and open in 2024 on the new laptop...
But like SLW210 says, there are many things that it could be  - hardware, software, drawing file that we are only guessing, if you can upload the file we can check if the issue is hardware (if we can open it OK, it isn't that), software (likewise), or drawing file
  • Agree 1
  • 1 year later...
However... a year later the OP might have fixed their issue? (joined, posted 1 post, never came back to see any responses)
