pyou Posted October 14, 2023 Share Posted October 14, 2023 (edited) Hi all I am wondering if there is a chance to create a lisp which could hatch circular/rectangular objects which are on specific layers? For example: Layer1 - have various data including various dimensions circles/rectangles ( some of them may overlap each over) Layer2 - have various data including various dimensions circles/rectangles ( some of them may overlap each over) and so on... Is there a way to run a lisp to hatch them as SOLID and put hatch on different layer called Features_Hatch ? I hope I could explain clearly Thank you for your help! Edited October 14, 2023 by pyou additional text Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 14, 2023 Share Posted October 14, 2023 Just look at the -hatch command in lisp, you can do a ssget using filters '((0 . "Circle" "Lwpolyline")) then loop through the selection set. (command "-hatch" "s" ent "" "P" "solid" "") Have a go plenty here will help. Quote Link to comment Share on other sites More sharing options...
Steven P Posted October 15, 2023 Share Posted October 15, 2023 Don't need to loop through the selection set, just use it straight in the hatch Edit the below to filter the selection set as you want (objects, layers, etc) (defun c:test ( / Lay_Old MySS ) (setq Lay_Old (getvar 'clayer)) ;record the current layer (setvar 'clayer "Features_Hatch") ;set the layer to Features_Hatch. This layer has to exist else error (setq MySS (ssget)) ; Select the objects you want, refer to http://www.lee-mac.com/selsetprocessing.html for filter options (command "-hatch" "s" MySS "" "P" "solid" "") ; hatch the selection set (setvar 'clayer Lay_Old) ; reset the layer to 'current layer' (princ) ; end quietly ) ; end function Quote Link to comment Share on other sites More sharing options...
pyou Posted October 15, 2023 Author Share Posted October 15, 2023 (edited) Thank you Steven P and Bigal. I would need to create separate hatches for each circular/rectangular object and not just single hatch for all the objects. Also where do i need to type specific layer names to hatch without selecting anything in cad? for example layers called in cad are named as Layer1; Layer2; etc. Also a good tweak to the lisp would be to send hatch to the back Edited October 15, 2023 by pyou Quote Link to comment Share on other sites More sharing options...
pyou Posted October 15, 2023 Author Share Posted October 15, 2023 This lisp almost working, how to make it work on 3dpolylines? This time i have attached dwg example. (defun c:test ( / Lay_Old MySS target_layers ) (setq Lay_Old (getvar 'clayer)) ; Record the current layer (setvar 'clayer "Features_Hatch") ; Set the layer to Features_Hatch. This layer must exist else an error will occur ; Define a list of layers for hatching (setq target_layers '("Layer1" "Layer2" "Layer3")) (foreach layer_name target_layers (setq MySS (ssget "X" (list '(0 . "LWPOLYLINE,CIRCLE,ARC,RECTANGLE") (cons 8 layer_name)))) (if MySS (progn (setq i 0) (repeat (sslength MySS) (setq ename (ssname MySS i)) (command "-hatch" "S" ename "" "P" "Solid" "") (setq i (1+ i)) ) ) ) ) (setvar 'clayer Lay_Old) ; Reset the layer to the original current layer (princ) ; End quietly ) test.dwg 2 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 15, 2023 Share Posted October 15, 2023 You forgot this put before hatch line. (setvar 'clayer lay_name) The filter for a 3dpoly is "Polyline". 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted October 16, 2023 Share Posted October 16, 2023 8 hours ago, BIGAL said: The filter for a 3dpoly is "Polyline". Could also do polyline as a wildcard, *, should get LW and 3D polylines (setq MySS (ssget "X" (list '(0 . "*POLYLINE,CIRCLE,ARC,RECTANGLE") (cons 8 layer_name)))) (tip for the OP, type this in the command line and it will return the entity description, select the type you want and copy the entity type as required: (Entget(Car(Entsel "Select Object"))) ) 1 Quote Link to comment Share on other sites More sharing options...
pyou Posted October 16, 2023 Author Share Posted October 16, 2023 (edited) Thank you all. The next step would be: Some features are not only circles and rectangles but circular and triangle block reference objects. How do I include these to be hatches as well, please? Do i have to specify block reference names in the lisp to be hatch, or not necessary? I have attached test2 dwg example Updated lisp so far: (defun c:test ( / Lay_Old MySS target_layers ) (setq Lay_Old (getvar 'clayer)) ; Record the current layer (setvar 'clayer "Features_Hatch") ; Set the layer to Features_Hatch. This layer must exist else an error will occur ; Define a list of layers for hatching (setq target_layers '("Layer1" "Layer2" "Layer3")) (foreach layer_name target_layers (setq MySS (ssget "X" (list '(0 . "*POLYLINE,CIRCLE,ARC,RECTANGLE") (cons 8 layer_name)))) (if MySS (progn (setq i 0) (repeat (sslength MySS) (setq ename (ssname MySS i)) (command "-hatch" "S" ename "" "P" "Solid" "") (setq i (1+ i)) ) ) ) ) (setvar 'clayer Lay_Old) ; Reset the layer to the original current layer (princ) ; End quietly ) test2.dwg Edited October 16, 2023 by pyou Quote Link to comment Share on other sites More sharing options...
pyou Posted October 16, 2023 Author Share Posted October 16, 2023 (edited) I have managed to get it right , as it seems to work ok. (defun c:test ( / Lay_Old MySS target_layers ) (setq Lay_Old (getvar 'clayer)) ; Record the current layer (setvar 'clayer "Features_Hatch") ; Set the layer to Features_Hatch. This layer must exist else an error will occur ; Define a list of layers for hatching (setq target_layers '("Layer1" "Layer2" "Layer3")) ; Define a list of block names to hatch (setq block_names '("CIRCL" "Triangle")) (foreach layer_name target_layers (setq MySS (ssget "X" (list '(0 . "*POLYLINE,CIRCLE,ARC,RECTANGLE") (cons 8 layer_name)))) (if MySS (progn (setq i 0) (repeat (sslength MySS) (setq ename (ssname MySS i)) (command "-hatch" "S" ename "" "P" "Solid" "") (setq i (1+ i)) ) ) ) ; Hatch block references (foreach block_name block_names (setq MySS (ssget "X" (list '(0 . "INSERT") (cons 8 layer_name) (cons 2 block_name)))) (if MySS (progn (setq i 0) (repeat (sslength MySS) (setq ename (ssname MySS i)) (command "-hatch" "S" ename "" "P" "Solid" "") (setq i (1+ i)) ) ) ) ) ) (setvar 'clayer Lay_Old) ; Reset the layer to the original current layer (princ) ; End quietly ) Edited October 16, 2023 by pyou 1 Quote Link to comment Share on other sites More sharing options...
pyou Posted October 16, 2023 Author Share Posted October 16, 2023 (edited) I would like to change Hatch from SOLID to ANSI31 with a scale 0.03 , what changes do I need to make, please? I cant make scale to work. Edited October 16, 2023 by pyou Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 16, 2023 Share Posted October 16, 2023 Make the (if ss call a defun then no need for the code to be done twice. Type -hatch look at the options line you will see what you need to add to (command "-hatch" ???? Quote Link to comment Share on other sites More sharing options...
pyou Posted October 17, 2023 Author Share Posted October 17, 2023 (edited) I cant make it to work (command "-hatch" "S" ename "" "P" "ANSI31" "" "A" 0 "S" 0.03 "") Could someone be more specific, please. Edited October 17, 2023 by pyou Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 17, 2023 Share Posted October 17, 2023 Try a re-order (command "-hatch" "P" "ANSI31" 0.03 0.0 "S" ename "" "") 1 1 Quote Link to comment Share on other sites More sharing options...
martinle Posted October 19, 2023 Share Posted October 19, 2023 On 10/15/2023 at 9:44 PM, pyou said: Hello Pyou, that is very good. The only problem I have is that I can't use the all selection (ssget "X") but only a selection on the visible area of the screen. Could you help me what I need to rewrite in your great Lisp? Unfortunately I have no experience in Lisp. Thanks! Martin This lisp almost working, how to make it work on 3dpolylines? This time i have attached dwg example. (defun c:test ( / Lay_Old MySS target_layers ) (setq Lay_Old (getvar 'clayer)) ; Record the current layer (setvar 'clayer "Features_Hatch") ; Set the layer to Features_Hatch. This layer must exist else an error will occur ; Define a list of layers for hatching (setq target_layers '("Layer1" "Layer2" "Layer3")) (foreach layer_name target_layers (setq MySS (ssget "X" (list '(0 . "LWPOLYLINE,CIRCLE,ARC,RECTANGLE") (cons 8 layer_name)))) (if MySS (progn (setq i 0) (repeat (sslength MySS) (setq ename (ssname MySS i)) (command "-hatch" "S" ename "" "P" "Solid" "") (setq i (1+ i)) ) ) ) ) (setvar 'clayer Lay_Old) ; Reset the layer to the original current layer (princ) ; End quietly ) test.dwg 22.75 kB · 4 downloads Quote Link to comment Share on other sites More sharing options...
pyou Posted October 19, 2023 Author Share Posted October 19, 2023 14 hours ago, martinle said: Hi martinle unfortunately, I am not that experienced either, hopefully other group members could help you? 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted October 20, 2023 Share Posted October 20, 2023 Change this: (setq MySS (ssget "X" (list '(0 . "LWPOLYLINE,CIRCLE,ARC,RECTANGLE") (cons 8 layer_name)))) to (setq MySS (ssget "X" (list '(0 . "*POLYLINE,CIRCLE,ARC,RECTANGLE") (cons 8 layer_name)))) to also select 3d polylines. Are you wanting to select all - using the LISP in the example drawing it selects everything for me. To select what you want with the mouse, take away the "X" in the lines above Quote Link to comment Share on other sites More sharing options...
martinle Posted October 20, 2023 Share Posted October 20, 2023 Hello Steven, Unfortunately it doesn't work if I just remove the X. lg. Martin Quote Link to comment Share on other sites More sharing options...
pyou Posted October 20, 2023 Author Share Posted October 20, 2023 On 18/10/2023 at 00:55, BIGAL said: Try a re-order (command "-hatch" "P" "ANSI31" 0.03 0.0 "S" ename "" "") Thanks BIGAL, The issue I am facing now is if I start hatching objects manually using random layer , it keeps it. If I run lisp after , it uses the layer I had selected and not the''Features_hatch'' and ''chamber_hatch'' layer to hatch all objects. Is there a way to get around it ? P.S it uses correct Hatch patterns just not the layers they should be on. Quote Link to comment Share on other sites More sharing options...
Steven P Posted October 20, 2023 Share Posted October 20, 2023 10 hours ago, martinle said: Hello Steven, Unfortunately it doesn't work if I just remove the X. lg. Martin That's odd, it works for me with your example file both selecting everything ....(ssget "x" (list (.... or selecting with the mouse .... (ssget (list (.... Quote Link to comment Share on other sites More sharing options...
Steven P Posted October 20, 2023 Share Posted October 20, 2023 4 hours ago, pyou said: Thanks BIGAL, The issue I am facing now is if I start hatching objects manually using random layer , it keeps it. If I run lisp after , it uses the layer I had selected and not the''Features_hatch'' and ''chamber_hatch'' layer to hatch all objects. Is there a way to get around it ? P.S it uses correct Hatch patterns just not the layers they should be on. I'm not getting that, can you post an example drawing? Should be something simple Quote Link to comment Share on other sites More sharing options...
