grzegorz1928 Posted October 11, 2023 Posted October 11, 2023 Hi, I have a problem with copying a reference to a dynamic block from one drawing to another drawing containing the definition of the same block - their dynamic parameters are not preserved correctly. Comments: If I insert this block into a "clean" drawing, this problem does not occur. When I change the MIRRTEXT variable, the block looks different after pasting, but still incorrect. The procedure "_copyclip -> _pasteblock" does not solve this problem either. Copy: Paste: Thank you in advance for your help. base.dwgUnavailable insert.dwgUnavailable Quote
grzegorz1928 Posted October 11, 2023 Author Posted October 11, 2023 On 10/11/2023 at 11:32 AM, asos2000 said: Try ATTSYNC then select the block Unfortunately, this has no effect. Quote
SLW210 Posted October 11, 2023 Posted October 11, 2023 I do not have time to do a thorough test this morning, but my best guess is the way (order?) you have the actions/objects selected. So, probably a glitch in AutoCAD. Either way rebuilding from scratch might fix it. Quote
BIGAL Posted October 11, 2023 Posted October 11, 2023 Try changing the text insertion point to MC middle center this way the text rotates about a center point. Quote
