Can someone tell me step-by-step please how do I create egg in AutoCAD?
Thank you
One possible solution: Draw the profile using a polyline then use the Revolve command to create the egg.
How do I draw the profile as similar as possible to the real egg one?
You should search online for "The mathematics of egg shape"
Birds, inconveniently, do not have a standard egg former built in.
Expand
Import the image above and trace it?
3 simple ways: I think the shape is 2 ellipses stuck together, so make 2 shapes that intersect and trim:
Basic ellipse is quick and easy, circle and ellipse gives a squat looking egg, ellipse and ellipse is a more normal shape. Your artistic ability will determine the exact egg shape.
How do I trace it? I can't and I don't understand. Show me please.
Expand
 You can use the ATTACH command, in AutoCAD, to insert an image file then use whatever combination of DRAW commands to trace the edge of the egg.  It can be arc, line, polyline, ellipse and/or spline.
Edited by ReMark
Expand
How do I trace it using spline? Can you show me please using fit point.
Edited by basty
paste the image into CAD, turn off snaps, start spline command, then working from the top or bottom, just draw the spline with enough points so that it makes the shape of half the egg. mirror and join the 2 hlaves.
Curious what the purpose of the exercise is, a learning thing but is it for learning how splines work or something else. Note that tracing an image doesn't give a precise shape but might be good enough
In the image below, I created half the egg using 4 arc's.
To complete the drawing you can join the arc's together using the PEDIT command and then MIRROR across the centerline.
If you want to create a 3D model, you can join the arc's together with the PEDIT command and then REVOLVE around the centerline.
  On 10/8/2023 at 6:24 PM, basty said:
How many points?
Expand
That is up to you really. Have a go, post the results here and we can comment with more suggestions for improvements
I moved your thread, stop posting all of your threads in the beginners section.
