vanowm Posted October 3, 2023 Share Posted October 3, 2023 Hello. It seems autocad treats content of square brackets as clickable suggestions and forward slash being removed because it's used as a separator. Is there a way display it as text? (getint "[1/2]") Quote Link to comment Share on other sites More sharing options...
ronjonp Posted October 3, 2023 Share Posted October 3, 2023 4 hours ago, vanowm said: Hello. It seems autocad treats content of square brackets as clickable suggestions and forward slash being removed because it's used as a separator. Is there a way display it as text? (getint "[1/2]") Remove the brackets: (getint "1/2") Quote Link to comment Share on other sites More sharing options...
vanowm Posted October 3, 2023 Author Share Posted October 3, 2023 But I like my brackets! Yes, I know, next solution is to go back to Autocad 2000... Quote Link to comment Share on other sites More sharing options...
vanowm Posted October 3, 2023 Author Share Posted October 3, 2023 Square brackets were always representing "default" value if nothing was entered. So, I'd like to keep them. For now, my work around this is to use unicode full-width brackets: [ ] They look slightly different, but acceptable. (getint "[1/2]") Quote Link to comment Share on other sites More sharing options...
pkenewell Posted October 4, 2023 Share Posted October 4, 2023 @vanowm FWIW - Look at Autocad's general options on the command line for a typical command like COPY: Specify base point or [Displacement/mOde] <Displacement>: "[ ]" are always around the option keywords. "< >" are always around the default option. Capital letters are the mnemonic letter for the option keyword. I always stick to that when making my command prompts. 1 Quote Link to comment Share on other sites More sharing options...
vanowm Posted October 4, 2023 Author Share Posted October 4, 2023 Oh, you are correct. Not sure why it got stuck in my head square brackets where default value...mixed it with system console prompt I guess... 1 Quote Link to comment Share on other sites More sharing options...
