Display "[1/2]" in getXXX message as plain text, not clickable suggestions
vanowm
Hello.
It seems autocad treats content of square brackets as clickable suggestions and forward slash being removed because it's used as a separator. Is there a way display it as text?
(getint "[1/2]")
4 hours ago, vanowm said:
Hello.
(getint "[1/2]")
Remove the brackets: (getint "1/2")
Square brackets were always representing "default" value if nothing was entered. So, I'd like to keep them.
For now, my work around this is to use unicode full-width brackets: [ ]
They look slightly different, but acceptable.
(getint "[1/2]")
@vanowm FWIW -
Look at Autocad's general options on the command line for a typical command like COPY:
Specify base point or [Displacement/mOde] <Displacement>:
  • "[ ]" are always around the option keywords.
  • "< >" are always around the default option.
  • Capital letters are the mnemonic letter for the option keyword.
I always stick to that when making my command prompts.
  • Thanks 1
Oh, you are correct. Not sure why it got stuck in my head square brackets where default value...mixed it with system console prompt I guess...
