Statistics text DIM for calculation
HOang6893
Hello experts.
I'm having problems with the lisp I'm using. Specifically:
- When I set dim style > round off = 10 the lisp I am using still reports the dim values with round off = 0.
Can experts help me fix this error?
Thank you very much !
ccd.lsp Copy dim.dwg
Like this?
(defun c:ccd (/ gtt dt sdt ent id str)
	(setq dt (ssget '((0 . "DIMENSION")))
		sdt (sslength dt)
		id 0
		gtt 0
		str "="
	(repeat sdt
		(setq
			ent (ssname dt id)
			id (1+ id)
			gtt (+ gtt (gt1 ent) )
			str (strcat str  (Rtos (gt1 ent) 2 0 ) "+")
	(Lisped (substr str 1 (1- (strlen str))))
	(princ gtt)
(defun gt1 (ent / so ro)
	;; roundoff
	(setq ro (nth 0 (ParseIt (cdr (assoc 3 (entget ent))))))
	(if (wcmatch (cdr (assoc 1 (entget ent))) "")
		(setq so (LM:roundm (cdr (assoc 42 (entget ent))) ro))		;; round the value to ro
		(setq so (atof (cdr (assoc 1 (entget ent)))))
;; http://www.lee-mac.com/round.html
;; Round Multiple  -  Lee Mac
;; Rounds 'n' to the nearest multiple of 'm'
(defun LM:roundm ( n m )
    (* m (fix ((if (minusp n) - +) (/ n (float m)) 0.5)))
;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/extracting-numeric-values-on-a-string/td-p/784014
(defun ParseIt (str)
  (read
    (vl-list->string
      (append
        '(40) ; "(".
        (mapcar
          '(lambda (int) (if (or (= 46 int) (<= 48 int 57)) int 32))
          (vl-string->list str)
        '(41) ; ")".
Thanks Emmanuel Delay.
Your Lisp works exactly as I wanted.
