Hải_Duy Posted October 2, 2023 Share Posted October 2, 2023 i am looking for a lispcad that strips points on a curve to points on a straight line. help me create such a lisp, thanks! Drawing1.dwg Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted October 2, 2023 Share Posted October 2, 2023 (edited) Untested, but should work... Otherwise, good start point for develop... (defun c:stripptscur-lin ( / ss s1 i pt pl c dists len p ) (vl-load-com) (prompt "\nSelect curve with points that lie on it...") (if (setq ss (ssget)) (progn (sssetfirst nil ss) (setq s1 (ssget "_I" '((0 . "POINT")))) (sssetfirst) (repeat (setq i (sslength s1)) (setq pt (ssname s1 (setq i (1- i)))) (ssdel pt ss) (setq pl (cons (cdr (assoc 10 (entget pt))) pl)) ) (setq c (ssname ss 0)) (setq pl (vl-sort pl '(lambda ( a b ) (< (vlax-curve-getparamatpoint c a) (vlax-curve-getparamatpoint c b))))) (foreach p pl (setq dists (cons (vlax-curve-getdistatpoint c p) dists)) ) (setq len (vlax-curve-getdistatparam c (vlax-curve-getendparam c))) (initget 1) (setq p (getpoint "\nPick or specify point to place line : ")) (entmake (list (cons 0 "LINE") (cons 10 p) (cons 11 (polar p 0.0 len)))) (foreach dist (reverse dists) (entmake (list (cons 0 "POINT") (cons 10 (polar p 0.0 dist)))) ) ) ) (princ) ) HTH. M.R. Edited October 2, 2023 by marko_ribar 1 Quote Link to comment Share on other sites More sharing options...
Hải_Duy Posted October 2, 2023 Author Share Posted October 2, 2023 @marko_ribar thanks for your great code, it's helpful for me Quote Link to comment Share on other sites More sharing options...
