lisp turns points on a curve into points on a straight line
Untested, but should work... Otherwise, good start point for develop...
(defun c:stripptscur-lin ( / ss s1 i pt pl c dists len p )
  (vl-load-com)
  (prompt "\nSelect curve with points that lie on it...")
  (if (setq ss (ssget))
      (sssetfirst nil ss)
      (setq s1 (ssget "_I" '((0 . "POINT"))))
      (sssetfirst)
      (repeat (setq i (sslength s1))
        (setq pt (ssname s1 (setq i (1- i))))
        (ssdel pt ss)
        (setq pl (cons (cdr (assoc 10 (entget pt))) pl))
      (setq c (ssname ss 0))
      (setq pl (vl-sort pl '(lambda ( a b ) (< (vlax-curve-getparamatpoint c a) (vlax-curve-getparamatpoint c b)))))
      (foreach p pl
        (setq dists (cons (vlax-curve-getdistatpoint c p) dists))
      (setq len (vlax-curve-getdistatparam c (vlax-curve-getendparam c)))
      (initget 1)
      (setq p (getpoint "\nPick or specify point to place line : "))
      (entmake (list (cons 0 "LINE") (cons 10 p) (cons 11 (polar p 0.0 len))))
      (foreach dist (reverse dists)
        (entmake (list (cons 0 "POINT") (cons 10 (polar p 0.0 dist))))
HTH.
M.R.
Edited by marko_ribar
@marko_ribar
thanks for your great code, it's helpful for me 🍻
