help with routine...numerical filter
(setq nodwg (getstring "\nEnter the number"))
I have a routine to rename dwg files.
I use this line to enter part of the name
The data entered is always between 001   to 999
I would like you to help me with a filter so that it only accepts this number range and not letters.
I appreciate any comments
thanks
Consider something like the following:
(while
    (not
        (or
            (= "" (setq nodwg (getstring "\nEnter the number <exit>: ")))
            (wcmatch nodwg "###")
    (princ "\nNumber must be in the range 001-999.")
(if (/= "" nodwg)
        ;; do stuff
  • Like 3
  • Thanks 1
Excellent master, it worked perfectly  thanks
My first thought was to use getint, below works if you want the file number to have leading zeros (for numbers below 100).
(defun c:test ( / tmp pre)
  (setq tmp "")
  (setq pre (getint "Enter Drawing Number: "))
  (if (< pre 10)(setq tmp "0"))
  (if (< pre 100)(setq tmp (strcat tmp "0")))
  (setq pre (strcat tmp (rtos pre)))
  • Thanks 1
This is what I use for leading 0's
(defun AT:NumFix (s n)
 ;; Fix number string with leading zeros
 ;; s - Number string to fix
 ;; n - Number of characters for final string
 ;; Alan J. Thompson, 10.29.09
 ;; (AT:NumFix i 3) i= 1 = 001
  (if (< (strlen s) n)
    (AT:NumFix (strcat "0" s) n)
    s
(defun c:test (/ pre tmp)
  (if (and (setq pre (getint "Enter Drawing Number: ")) (> pre 0) (< pre 999))
    (setq tmp (AT:NumFix (itoa pre) 3))
    (Alert "\nNumber must be in the range 001-999.")
  tmp
  • Thanks 1
I do same as Steven P with 1 little change
(if (< pre 10)(setq tmp "00"))
