Hey,
I'm stuck again! I'm trying to find a way to use a common insertion point so that the user doesn't have too. The point of building this panel is to add dimensions and profiles to a block and then hit a "Create Panel" button to build the block. In this instance the user has already choose the dimension to create a box and pick a corner point. Well, I would like to use this corner point from the box as an insertion point for the part reference, text, and symbols (if needed). As you can see, VarPick under cmdCreatePanel is the point I'm trying to reference in for InsertionPnt under cmdWall. Thanks for your help!
Private Sub cmdWall_Click()
Dim InsertionPnt As Variant
Me.hide
InsertionPnt = ThisDrawing.Utility.GetEntity(varPick)
Dim ampartref As McadPartReference
Set ampartref = ThisDrawing.ModelSpace.AddCustomObject("AcmPartRef")
End Sub
'Combo Box for Panel Sizes
Private Sub UserForm_Activate()
cmbPanelWidth.AddItem "1'-0"""
cmbPanelWidth.AddItem "1'-0 1/2"""
cmbPanelWidth.AddItem "1'-1"
cmbPanelWidth.AddItem "10'-0"
cmbPanelLength.AddItem "10'-0"""
cmbPanelLength.AddItem "10'-0 1/2"""
cmbPanelLength.AddItem "10-1"""
cmbPanelHeight.AddItem "6"""
cmbPanelHeight.AddItem "8"""
cmbPanelHeight.AddItem "10"""
cmbPanelHeight.AddItem "12"""
End Sub
'Create Panel
Private Sub cmdCreatePanel_Click()
Dim varPick As Variant
Dim dblLength As Double
Dim dblWidth As Double
Dim dblHeight As Double
Dim dblCenter(2) As Double
Dim objEnt As Acad3DSolid
Me.hide
'get the input from user
With ThisDrawing.Utility
.InitializeUserInput 1
varPick = .GetPoint(, vbCr & "Pick a corner point: ")
.InitializeUserInput 1 + 2 + 4, ""
dblLength = .DistanceToReal(cmbPanelLength.Text, acEngineering)
dblWidth = .DistanceToReal(cmbPanelWidth.Text, acEngineering)
dblHeight = .DistanceToReal(cmbPanelHeight.Text, acEngineering)
End With
'calculate center point from input
dblCenter(0) = CDbl(varPick(0)) + (dblLength / 2)
dblCenter(1) = CDbl(varPick(1)) + (dblWidth / 2)
dblCenter(2) = CDbl(varPick(2)) + (dblHeight / 2)
'draw the entity
Set objEnt = ThisDrawing.ModelSpace.AddBox(dblCenter, dblLength, _
dblWidth, dblHeight)
objEnt.History = True
objEnt.Update
ThisDrawing.Regen acActiveViewport
Me.Show
End Sub
Private Sub cmdExit_Click()
Unload Me
End Sub
ANY suggestions or advice would be greatly appreciated!
Thank You in Advance! :)
what is your question exactly? I would use getpoint and make all my calculations from that point.
Thanks for your reply. I'm new at this. I'm not sure how to refer that point? Get Point is for user input. I want the part reference to automatically insert at that point.
Me.hide
'How do I get that insertion point from the corner point from Varpick??????? I want the point the
user initially picks when they insert the block.
InsertionPnt = ThisDrawing.Utility.GetPoint ()
InsertionPnt = ThisDrawing.Utility.TranslateCoordinates(InsertionPnt, acUCS, acWorld, False)
Dim mpartref As McadPartReference
Set mpartref = ThisDrawing.ModelSpace.AddCustomObject("AcmPartRef")
mpartref.Origin = InsertionPnt
End Sub[
