drdownload18 Posted September 20, 2023 Posted September 20, 2023 Is there a lisp or can it be made that would reshape the selected polyline or 3dpolyline to the closest points (in X,Y direction) after selection? Align_3dp_vert_to_nearest_points.dwg Quote
hosneyalaa Posted September 20, 2023 Posted September 20, 2023 try lisp from @ronjonp (defun c:s2o (/ a b c d el m s) ;; RJP » 2020-04-29 ;; Could give bad results for multiple vertices that are within the 'search distance' (cond ((and (setq d (getdist "\nPick a distance to search: ")) (setq s (ssget ":L" (list '(0 . "CIRCLE,INSERT,POINT,LWPOLYLINE")))) ) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (if (= "LWPOLYLINE" (cdr (assoc 0 (setq el (entget e))))) (setq b (cons (vl-remove-if '(lambda (x) (/= 10 (car x))) el) b)) (setq a (cons (list (cdr (assoc 10 el)) e) a)) ) ) (if (setq b (mapcar 'cdr (apply 'append b))) (foreach p a (setq c (mapcar '+ (car p) '(0 0))) (cond ((setq m (vl-some '(lambda (x) (if (equal c x d) x ) ) b ) ) (setq b (vl-remove m b)) (entmod (append (entget (cadr p)) (list (cons 10 (append m (list (last (car p)))))))) ) ) ) ) ) ) (princ) ) Quote
Emmanuel Delay Posted September 20, 2023 Posted September 20, 2023 It's a bit tricky. Your points are all on different Z-value You certainly cannot make a polyline that has different z-values for its vertices. So you want to replace the polyline by a newly drawn 3D Polyline Quote
Steven P Posted September 20, 2023 Posted September 20, 2023 They are asking for X-Y direction only, but likewise I would be tempted to make something up to cater for X-Y and X-Y-Z - versatility for others who follow. Does the OP want to retain any Z coordinate of the original polyline / 3D Polyline? Not had a chance to do much LISP recently, the guy who keeps paying me wants me to do what he pays me for. It might be easiest to create a new line to the points rather than modify the existing line - for example if there are more verticies in the line than there are points it might do something odd. So perhaps find the bounding box for the polyline and use the points as a 'crossing polygon' selection set, filter to points to find the points - perhaps offset a little, draw the line to suit and delete the original. Quote
Emmanuel Delay Posted September 20, 2023 Posted September 20, 2023 This code works for the example you provided. I'm not sure if it will work in all situations. The elevation is greater than the distance between points, so it may find the wrong point sometimes. (vl-load-com) ;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-get-the-z-coordinate-of-3d-polyline/td-p/2435197 ;; Poly-Pts ;;; returns a list of the polyline vertices WCS coordinates ;;; Argument: a polyline (ENAME or VLA-OBJECT) (defun poly-pts (p / n l) (setq n (fix (vlax-curve-getEndParam p))) (or (vlax-curve-IsClosed p) (setq n (1+ n))) (repeat n (setq l (cons (vlax-curve-getPointAtParam p (setq n (1- n))) l)) ) ) (defun draw3DWPoly (lst cls) (command "_3dpoly") (foreach a lst (command a) ) (command "") ) ;; RPTP for "Reshape Polyline To Points" (defun c:RPTP ( / pts pt dst closest_dst pl verts vrt i j ind pointlist) (princ "\nSelect points: ") (setq pts (ssget (list (cons 0 "POINT")))) (setq pl (car (entsel "\nSelect polyline: "))) ;; read the vertices of the polyline (setq verts (poly-pts pl)) ;; for each vertex find the closest points. ;; verts is already sorted from start to end (as the polyline was drawn) (setq pointlist (list)) (foreach vrt verts ;; (setq i 0) (setq closest_dst nil) (repeat (sslength pts) (setq dst (distance vrt ;; vertex (cdr (assoc 10 (entget (ssname pts i)))) ;; location of the POINT )) (if (= closest_dst nil) ;; first try (progn (setq closest_dst dst) (setq ind i) ;; we want to keep track of the index of the closest point ) ;; else, see if we get a closer match (if (< dst closest_dst) (progn (setq closest_dst dst) (setq ind i) ) ) ) (setq i (+ i 1)) ) (setq pointlist (append pointlist (list (cdr (assoc 10 (entget (ssname pts ind)))) ))) ;; remove the point from the list, so we don't look at the same point twice (ssdel (ssname pts ind) pts) ) (princ pointlist) (draw3DWPoly pointlist 0) (entdel pl) ) 1 Quote
