Guest Posted September 16, 2023 Posted September 16, 2023 Hi, I'm having this annoying issue where I'm trying to edit my editable poly by clicking 1, 2, 3, 4, or 5 as shortcuts to get to the components of the poly, but in many cases I have added a modifier which does not allow me to shortcut directly to editing the poly. So I'm force's to use the mouse to manually take me to editing the poly components instead of the shortcut. Any shortcuts to getting directly to editing the components of the poly even if the modifier is obstructing it? Thanks. Quote
Cad64 Posted September 18, 2023 Posted September 18, 2023 I haven't used 3ds Max in years, but would it be helpful to add an Edit Poly modifier to the top of the stack? Quote
Guest Posted September 20, 2023 Posted September 20, 2023 Thanks for your reply. Tried it but it gives me a warning when I go to the modifier stack about undesirable effects. I just want to jump to the original edit poly components with a shortcut... Quote
