Need some help with CLAYER not being restored
EYNLLIB
(defun c:DC ( / curlay)
  (setq curlay (getvar "CLAYER"))
  (command
    "_.layer" "_set" "S - DETAIL CUT" ""
    "_.insert" "Detail Cut" "_scale" 36
    "_.layer" "_set" curlay ""
After the block is inserted on the proper layer per the code, the layer is not being reset properly to the previous current layer.
Any help would be appreciated, I'm still learning lisp
Give this a try:
  (setvar "clayer" "S - DETAIL CUT")
  (vl-cmdf "._insert" "Detail Cut" "_s" 36.0 "_r" 0)
  (setvar "clayer" curlay)
  • Like 2
On 9/16/2023 at 12:40 PM, rkmcswain said:
Give this a try:
I tried your solution but the layer is not reset to curlay properly.
I managed to find in a fix for my code by adding a pause after the rotate. see below;
  (setvar 'cmdecho 0)
    (command
    "_.insert" "Detail Cut" "_scale" 36 "_rotate" 0 pause
  (setvar 'cmdecho 1)
(Princ)
