Hi, I found OneMtext.lsp and Text2MTextV2-0.lsp which are both very useful for my needs, but I wish that the contents could be set to sort by alphabetical order. Can anybody help me or point me in the direction of how to modify the lisp so I can have this result?
Thank you
OneMtext.lspFetching info... Text2MTextV2-0.lspFetching info...
Edited by fefaleite
(defun 1MT (break / *error* done e objlst obj wid str strllen strlist) ; <- add these 2 variable name
      (setq str (vla-get-TextString obj))
      ; Insert these lines below this line.
      (setq strlist (list str))
      (foreach x (cdr objlst)
        (setq str (vla-get-TextString x))
        (setq strlist (cons str strlist))
      ); foreach
      (setq strlist (vl-sort strlist '<))
        (vla-delete x)
      (setq str (car strlist))
      (setq strlist (cdr strlist))
      (setq strllen (length strlist))
      (repeat strllen
        (setq str (strcat str break (car strlist)))
      ; up to this line
      (vla-put-TextString obj str)
This is a modification of 1MT.
Just add these lines in defun 1MT.
or
You can do this by creating a new command by adding the original, ascending sort, and descending sort options.
first, Add 0 one by one to the original 3 commands
and add sort, reverse sort commands
; original
(defun C:1MT0 (); all in one paragraph -- 1 space between, no Enter
  (1MT " " 0); Space for 'break' argument in 1MT
(defun C:1MT1 (); new paragraph for each object's content -- 1 Enter
  (1MT "\\P" 0); Enter for 'break' argument in 1MT
(defun C:1MT2 (); blank line & new paragraph for each object's content -- 2 Enters
  (1MT "\\P\\P" 0); 2 Enters for 'break' argument in 1MT
; sort (Ascending)
(defun C:1MTS0 () (1MT " " 1) (princ))
(defun C:1MTS1 () (1MT "\\P" 1) (princ))
(defun C:1MTS2 () (1MT "\\P\\P" 1) (princ))
; reverse sort (descending)
(defun C:1MTRS0 () (1MT " " 2) (princ))
(defun C:1MTRS1 () (1MT "\\P" 2) (princ))
(defun C:1MTRS2 () (1MT "\\P\\P" 2) (princ))
then, add sortoption to argument
(defun 1MT (break sortoption / *error* done e objlst obj wid str strllen strlist)
then modify the above code by adding (cond) like this.
      (cond
        ((= sortoption 0)
        ((or (= sortoption 1) (= sortoption 2))
          ); foreach
          (cond
            ((= sortoption 1)
            ((= sortoption 2)
              (setq strlist (vl-sort strlist '>))
            (vla-delete x)
          (repeat strllen
        (t
      ; up to this line
Edited by exceed
  • Like 2
