Thibaud Posted September 10, 2023 Posted September 10, 2023 Hello everyone, So I've had a recurring operation for many years and clearly it's not fun :) (in addition to the waste of time). I don't think I'm the only one in this situation, so I think it might help! Once my drawings are completed, I need to create dxf files. So far everything is normal. But then I have to open and dump these dxfs then save. One by one, it's looooooooong (less than 10sc going hard, but when you have 200 to go......) So I would like to create a lisp to save me time. Once the dxf file is opened, the lisp should be able to perform in one go and in order: -Explode the blocks -Delete 2 layers and what they contain (dimensions, line, polyline etc etc) "axes" layer and "defpoint" layer. -Transform the elements of layer 0 into a "contour" layer -Purge everything -Save in dxf2000 format. Or just save in default format, I can put the dxf200 as default beforehand. Thank you so much! Quote
SLW210 Posted September 11, 2023 Posted September 11, 2023 Sounds like you need to setup and run a batch script. Solved: Apply script to multiple drawings - Autodesk Community - AutoCAD Creating a batch file to run dwg to dxf scripts - AutoCAD Beginners' Area - AutoCAD Forums (cadtutor.net) Quote
