SHI5AG89 Posted September 7, 2023 Posted September 7, 2023 I have a problem... I need to make a routine for myself and my co-workers.. ok here is the situation. We will have a polyline created from a series of points, where we need to plot dimensions perpendicular to the proposed line stating the difference between the proposed and existing. It is something like this: An auto dimension lisp will help us a lot as we will have lots of dimensions in our daily routine. Thanks a lot in advance... TEST1.dwg Quote
Emmanuel Delay Posted September 19, 2023 Posted September 19, 2023 (edited) I made something. But you do need to - either make the red polyline 1 closed polyline - or cut the grey polyline in single side polylines. The grey and red polylines mush match one to one. See my upload as example. Option 1 will cause problems in the corners. Option 2 is probably more preferred. - command ADBP, for Auto Dimensions Between Polylines - select grey polyline, then select red polyline. (first set the layer to whatever layer you want the dimensions to be drawn on) (vl-load-com) ;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-get-the-z-coordinate-of-3d-polyline/td-p/2435197 ;; Poly-Pts ;;; returns a list of the polyline vertices WCS coordinates ;;; Argument: a polyline (ENAME or VLA-OBJECT) (defun poly-pts (p / n l) (setq n (fix (vlax-curve-getEndParam p))) (or (vlax-curve-IsClosed p) (setq n (1+ n))) (repeat n (setq l (cons (vlax-curve-getPointAtParam p (setq n (1- n))) l)) ) ) (defun draw_DIMALIGNED (p13 p14 p10 / ) (command "_.DIMALIGNED" p13 p14 p10) (entlast) ) ;; command ADBP for Auto Dimensions Between Polylines (defun c:ADBP ( / pl1 pl2 pts p13 p14) (setq pl1 (car (entsel "\nSelect polyline 1 (with the many endpoints): "))) (setq pl2 (car (entsel "\nSelect polyline 2 (red polyline): "))) (setq pts (poly-pts pl1)) (foreach p13 pts (setq p14 (vlax-curve-getClosestPointTo (vlax-ename->vla-object pl2) p13)) ;; draw DIMALIGNED (draw_DIMALIGNED p13 p14 p14) ) ) TEST1.dwg Edited September 19, 2023 by Emmanuel Delay Quote
SHI5AG89 Posted October 10, 2023 Author Posted October 10, 2023 Dear Emmanuel Delay Thanks a lot... This really works well with option 2. Thanks a lot again. 1 Quote
SHI5AG89 Posted August 24, 2024 Author Posted August 24, 2024 Dear sir On continuation to the above ADBP routine Will there be any option for automatic prefix - plus or minus values to be displayed. temp.dwg Quote
