ergunaksoy Posted September 7, 2023 Share Posted September 7, 2023 Hello guys, I hope you are all fine. I am looking for a LISP, because I tried to create for myself and unluckt it does not work. I want to explain : this is my DWG, i mean how it looks like: As you can see there is 2 type of Blocks. one is small and the other is big one. These types is not always square, they could be circle/rectangle etc. I can count first block with select similar or qselect, also I can count second object. But I want to count these objects that I marked. I created myself a lsp like this: Select block one, select block two, calculate distance, add tolarence +-5 to this distance and find these that they have same distance, but did not work. Can you help me please? Quote Link to comment Share on other sites More sharing options...
dan20047 Posted September 7, 2023 Share Posted September 7, 2023 Can you post your lisp to show where it doesn't work? Quote Link to comment Share on other sites More sharing options...
Steven P Posted September 7, 2023 Share Posted September 7, 2023 So you could use ssget (see http://lee-mac.com/ssget.html ) to select block 1: This will select all blocks. (setq ss (ssget "_X" ' ((0. "INSERT") (2. "Block Name"))) ) Then loop through the selection set with a while, repeat foreach or however loop Using the selected block you can get it's insert point: (setq MyBlock (ssname ss count)) ; where count is the item number in the selection set (set pt (cdr (assoc 10 (entget Myblock)))) ; gets the insertion point of the block And then back to selection set, select all block 2 that lie within an area of this insertion point: (setq pt1 (mapcar '+ (-5 -5 0) pt)) ; 4 corners of a rectabgle round the block (setq pt2 (mapcar '+ (-5 +5 0) pt)) (setq pt3 (mapcar '+ (+5 +5 0) pt)) (setq pt4 (mapcar '+ (+5 -5 0) pt)) (setq ss2 (ssget "_CP" (list pt1 pt2 pt3 pt4) '((2 . "Block Name 2")) )) and work out if ss2 is nil or a list - if it is a list then count it. Might work (CAD is off for today so the above is untested but might point you near to what you want) As Dan above, post your LISP if you can and it might be a simple change in that to make it work - keeping the work you did 2 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 8, 2023 Share Posted September 8, 2023 "rectabgle" a new Autocad object 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted September 8, 2023 Share Posted September 8, 2023 2 hours ago, BIGAL said: "rectabgle" a new Autocad object It should be! Quote Link to comment Share on other sites More sharing options...
Steven P Posted September 8, 2023 Share Posted September 8, 2023 If you post the LISP you had and a sample drawing, you might get some more finished advice Quote Link to comment Share on other sites More sharing options...
