Automatically open all DXF files in a folder and save them as DWG
Hi, I usually use WSCRIPT Lisp to automatically perform small operations on a series of files.
one of these is for example the combination of: open+zoom extensions+save, which I write in the following way:
_.open *file* _.zoom _e _.save  _Y _.close
I have to perform the same operation in a DXF file folder, open all DXF files and save them in DWG,  but the command described above does not start the procedure
how the reference should be corrected
_.open *file*
to correctly refer to DXF files?
Thank you in advance
Thank You very much!  and thanks also to VVA!
