is there lisp for fill polygone/polyline with block like adarray lisp. adarray lisp cannot use in my cad
;;;Cadalyst AutoLISP Solutions	July 2007	ALSPSOL0707.ZIP / ADARRAY.LSP 	(c) Tony Hotchkiss
(defun err (s)
  (if (= s "Function cancelled")
    (princ "\nADARRAY - cancelled: ")
    (progn (princ "\nADARRAY - Error: ")
	   (princ s)
	   (terpri)
    ) ;_ progn
  ) ;_ end of if
  (resetting)
  (princ "SYSTEM VARIABLES have been reset\n")
) ;_ end of err
(defun setv (systvar newval)
  (setq x (read (strcat systvar "1")))
  (set x (getvar systvar))
  (setvar systvar newval)
) ;_ end of setv
(defun setting ()
  (setq oerr *error*)
  (setq *error* err)
  (setv "CMDECHO" 0)
  (setv "BLIPMODE" 0)
  (setv "OSMODE" 0)
  (setv "CLAYER" (getvar "CLAYER"))
) ;_ end of setting
(defun rsetv (systvar)
  (setvar systvar (eval x))
) ;_ end of rsetv
(defun resetting ()
  (rsetv "CMDECHO")
  (rsetv "BLIPMODE")
  (rsetv "OSMODE")
  (rsetv "CLAYER")
  (setq *error* oerr)
) ;_ end of resetting
(defun adarray ()
  (vl-load-com)
  (setq	*thisdrawing* (vla-get-activedocument
			(vlax-get-acad-object)
		      ) ;_ end of vla-get-activedocument
	*modelspace*  (vla-get-ModelSpace *thisdrawing*)
  ) ;_ end of setq
  (setq	bnameindex nil)
  (setq doit 4)
  (setq ad_id (load_dialog "adarray.dcl"))
  (while (>= doit 2)
    (if	(not (new_dialog "adarray" ad_id))
      (exit)
    ) ;_ end of if
    (init-array)
    (action_tile "bname" "(setq bnameindex (atoi $value))")
    (action_tile "row" "(setq *rowdist* (atof $value))")
    (action_tile "col" "(setq *coldist* (atof $value))")
    (action_tile "pick" "(done_dialog 3)")
    (action_tile
      "accept"
      "(get-adarray-data) (done_dialog 1)"
    ) ;_ end of action_tile
    (setq doit (start_dialog))
    (cond
      ((= doit 1)
       (do-array)
      ((= doit 3)
       (setq *point0* (getpoint "\nPick a point: "))
    ) ;_ end of cond
  ) ;_ end of while
  (unload_dialog ad_id)
) ;_ end-of adarray
(defun init-array ()
  (setq	blks (vla-get-blocks *thisdrawing*)
	num  (vla-get-Count blks)
	*blknames* nil
	i 1
  ) ;_ end of setq
  (repeat (- num 2)
    (setq blk	   (vla-item blks (setq i (1+ i)))
	  bname	   (vla-get-Name blk)
	  *blknames* (append *blknames* (list bname))
    ) ;_ end of setq
  ) ;_ end of repeat
  (if *blknames*
      (start_list "bname")
      (mapcar 'add_list *blknames*)
      (end_list)
    ) ;_ end of progn
  ) ;_ end of if
  (if bnameindex
    (set_tile "bname" (itoa bnameindex))
  ) ;_ end of if
  (if *rowdist*
    (set_tile "row" (rtos *rowdist*))
    (set_tile "row" "2")
  ) ;_ end of if
  (if *coldist*
    (set_tile "col" (rtos *coldist*))
    (set_tile "col" "2")
  ) ;_ end of if
) ;_ end of init-array
(defun get-adarray-data ()
  (setq bnameindex (atoi (get_tile "bname")))
  (setq *bname* (nth bnameindex *blknames*))
  (setq *rowdist* (atoi (get_tile "row")))
  (setq *coldist* (atoi (get_tile "col")))
) ;_ end-of get-tool-data
(defun do-array ()
  (setq lyr "arr-hatch")
  (vl-cmdf "Layer" "M" lyr "C" "green" "" "")
  (vl-cmdf "-Hatch" *point0* "P" "U" "0.0" *rowdist* "N" "")
  (vl-cmdf "Explode" (entlast))
  (setq	ss     (ssget "X"
		      (list '(0 . "LINE")
			    (cons 8 lyr)
		      ) ;_ end of list
	       ) ;_ end of ssget
	num    (sslength ss)
	i      -1
  ) ;_ end of setq
  (rsetv "CLAYER")
  (repeat num
    (setq en (ssname ss (setq i (1+ i))))
    (vl-cmdf "Measure" en "B" *bname* "Y" *coldist*)
    (entdel en)
  ) ;_ end of repeat
) ;_ end of do-array
(defun c:ad ()
  (setting)
  (adarray)
  (resetting)
) ;_ end of c:ad
(prompt "\nCopyright (c) 2007, Tony Hotchkiss")
(prompt "\nEnter AD to start")
adarray cant use in my cad. it show image.png.bbc3e3dc8463d751e0ca524657088426.png
adarray.LSP adarray.DCL
make point with this
then use point to block lisp routine.
like this
(defun c:pt2blk (/ ss i pt ptlist blk blkent delss dellist )
  (princ "\n select points : ")
  (setq ss (ssget '((0 . "point"))))
  (princ "\n select a block : ")
  (setq blk (car (entsel)))
    (setq pt (list (cdr (assoc 10 (entget (ssname ss (setq i (1- i))))))))
    (setq ptlist (append ptlist pt))
  (while (/= "INSERT" (cdr (assoc 0 (entget blk))))
    (prompt "\n this is not a block. retry.")
    (setq blk (car (entsel "\n select a block : ")))
  (setq blkent (entget blk))
  (foreach x ptlist
    (entmake (subst (cons 10 x) (assoc 10 blkent) blkent))
  (entdel blk)
  (repeat (setq n (sslength ss))
    (setq delss (list (ssname ss (setq n (1- n)))))
    (setq dellist (append dellist delss))
  (foreach x dellist
    (entdel x)
