Hi gents ,
This section of the forum "AutoLisP , Visual LisP & DCL" is ONLY for AutoCAD , or can be used for any other software which is working with this kind of files ?
Sorry if I asked a silly question .
The below code is working fine in AutoCAD .
 (setq r (/ (getVar "ViewSize") 80)  r- (- r)  p '(10 7 0)
       transL (list (list 1  0. 0. (car p)) (list 0. 1  0. (cadr p)) (list 0. 0. 1 (caddr p)) (list 0. 0. 0. 1.) )  )
 (grVecs (list 1 (list r- r-) (list r r-) 2 (list r r-) (list r r) 3 (list r r) (list r- r) 4 (list r- r) (list r- r-) ) transL)
But in ZWcad the variable list transL doesn't have any effect . The rectangle is going in origin  , no matter where point p is .
It is not an oSnap issue .
The colored square should be inside of the circle .
Any suggestion ?
Edited by Costinbos77
The Grvecs is (list color pt1 pt2 color pt2 pt3 color pt3 pt24 etc. This worked for me.
(grVecs (list 1 (list r- r-) (list r r-) 2 (list r r-) (list r r) 3 (list r r) (list r- r) 4 (list r- r) (list r- r-) ))
But it is in wrong spot.
tansl does not make sense
((1 0.0 0.0 10) (0.0 1 0.0 7) (0.0 0.0 1 0) (0.0 0.0 0.0 1.0))
(setq transl (list 1 (list 7 4) (list 13 4) 2 (list 13 4) (list 13 10) 3 (list 13 10) (list 7 10) 4 (list 7 10) (list 7 4)))
(grVecs transl)
Thanks BigAl.
1. But unfortunately , I really need the transL list , because P is not static , it is dynamic , from grRead sequence. I don't put it in my example because I wanted it to be easy & simple one .
So , I need the rectangle to move simultaneously with the mouse cursor .
2. I received the ensure from ZWcad , saying grVecs can have a bug . They will check .
The below code has the same result as my one .
(grVecs (list 1 (list r- r-) (list r r-) 2 (list r r-) (list r r) 3 (list r r) (list r- r) 4 (list r- r) (list r- r-) ) nil)
That means is not interpreting my transL list .
3. To avoid all of this , I can use plan B : to calculate myself all 4 corners :
(setq c1 (mapcar '+ p (list r- r-)) )
(setq c2 (mapcar '+ p (list r r-)) )
(setq c3 (mapcar '+ p (list r r)) )
(setq c4 (mapcar '+ p (list r- r)) )
(grVecs (list 1 c1 c2 2 c2 c3 3 c3 c4 4 c4 c1) nil)
That will work very well in this case .
But , this means I need to calculate myself all the time in my other programs when I use the function grVecs with a translation list .
Unfortunately , for my oSnap function ,  grVecs is using 3 , 4 corners or multiple dots to simulate a circle . In that case , will be a nightmare without a  translation list .
I hope ZWcad will fix the problem .
That is what you have to do with grvecs keep changing the pt values, the other way is make a rectang, then use move you can get the 4 corner values once you finish dragging, then erase rectang.
i think, it is true that zwcad has a problem in grvec trans.
In zwcad, Lee Mac's GrSnap is also fixed to the origin in the same way and does not work.
There are still a few more bugs remaining in zwcad.
For example, if user run a Lisp containing LM:ENDUNDO LM:STARTUNDO.
sometimes It has to return a flag and escape the while, but it continues to run while infinitely
It seems like they only considered simply turning the flag on and off. I think the priorities are weird.
this is very critical problem but has not been fixed in 2019, 2022.
and acet-, ai-, control a zwcad in VBA, script writer, object DBX... etc.
with a little effort, most things are possible in zwcad. but it feels like some screw is missing. I think grvecs is like that too.
Edited by exceed
* Thanks BigAl ,
This can be a good plan C as well . The problem with this approach is the rectangle will influence the Osnap . But yes , can be applied in some cases .
* Thanks @exceed .
I was guessing ZWcad is not as stable as AutoCAD . It is not my choice , but I need to adapt my lisps to ZWcad as well , because some people are migrating to it .
To be honest , I was expecting more incompatibilities .
The major one is not compiling Line files .shp in .shx .
By the way , @exceed :
1 . Did you manage to load files for complex lines as  .shx .
2. Do you know a dedicated forum for AutoLisp for ZWcad ?
Thanks in advance .
Sorted :
1 . User Complex lines .
in AutoCAD :
;;  These linetype definitions use LTYPESHP.SHX.
*FENCELINE1,Fenceline circle ----0-----0----0-----0----0-----0--
A,.25,-.1,[CIRC1,lTypeShp.shx,x=-.1,s=.1],-.1,1
My customized complex line :
;;  These linetype definitions use MyFile.SHX.
*MYLINE,Line with circle ----0-----0----0-----0----0-----0--
A,.25,-.1,[CIRC1,MyFile.shx,x=-.1,s=.1],-.1,1
AutoCAD can search and read the file MyFile.shx if it is in the searching path .
ZWcad can access only the file lTypeShp.shx . So , if all the user's definitions for complex lines are included there , will work fine .
Of course , lTypeShp.shx file is coming from compiled lTypeShp.shp .
2 . ZWcad ensured NO dedicated forum for AutoLisp for ZWcad at the moment .
Did you contact ZWcad for help ?
CAD Forum - How to convert font and shape files SHX back to SHP?
https://www.cadforum.cz/en/how-to-convert-font-and-shape-files-shx-back-to-shp-tip11041
Add yours then do shp to shx
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Compile-shape-file-into-SHX-text-font-file.html
Pretty sure there is a mkshx program.
Edited by BIGAL
Hi BigAl ,
Yes, I sent them an email about this . Will see .
Great , your links are brilliant ! I didn't know could reverse .shx to .shp .
Was very hard to run it , until I found this guide for dumpshx.exe .
I will reproduce it below in case the link disappears :
1. Copy file from "C:\Program Files\Autodesk\AutoCAD 20??\Express\dumpShx.exe" to short and easy path "C:\Test\dumpShx.exe"
You can even rename the file as "c:\1\d.exe" , TO BE EASY TO WRITE IN the COMMAND PROMPT .
2. Open Command Prompt for Windows , usually by writing in the down-left box .
3. Write to go in your Desired director : cd c:\test\ ;
4. Write all in ONE LINE as  :   dumpShx.exe   -o  c:\test\ltypeshp.shp    c:\test\ltypeshp.shx  and press ENTER .
or more easy  :   dumpShx.exe   -o  c:\t\2.shp    c:\t\1.shx   or   :   dumpShx.exe   -o  d:\2.shp    d:\1.shx    and press ENTER .
5. Enjoy !
Picture attached .
Just type cmd in the box then enter.
