Lee Mac's Dynamic Information Tool...angle? Please help.
It is easy to know the angle of a line, but it is difficult to know the angle of a polyline because it has many nodes.
I haven't read all of them, but his code has very clear structure,
so, It can be applied with very little modifications.
approx. 403 line, you have to add "ANGLE"
                (setq tStr (strcat "{\\C4;" (dxf 0 iLst) "}"))
                (foreach prop
                    ANGLE
                    LAYER
                    COLOR
                    LINETYPE
                    LINEWEIGHT
even if put only these 5 characters
then test it, the radian angle will appear.
and if you want degree,
you have to add these 4 lines
  (eq prop 'ANGLE)
  (vl-princ-to-string (* 180 (/ (vlax-get-property iObj prop) pi)))
in approx. 450 line, inside of (cond~~)
like this
                          (cond
                              (eq prop 'COLOR)
                              (_GetColour iLst)
                              (eq prop 'ANGLE)
                              (vl-position prop '(DISPLAYLOCKED CLOSED))
                              (_Stringify (vlax-get-property iObj prop))
Edited by exceed
A bit off-topic.
is it just me or it does not work if the UCS is not set to World?
19 hours ago, nod684 said:
A bit off-topic.
Not just you.
Won't play at all for me if UCS not set to World.
Steve
  • Agree 1
It's perfect. Thank you, exceed.
