Dien nguyen Posted August 26, 2023 Posted August 26, 2023 I'm searching the forums for how to create multileader, I found the following lisp to create it but they don't have Arrowhead installed, I tried with parameter: '("ArrowSymbol" . "LA-ARRW") , but it don't work. Can it be fixed? (defun CreateMLeaderStyle (CMS_NewName CMS_Config / CMS_TextStyle CMS_MLeaderStyles CMS_NewMLeaderStyle CMS_Property CMS_ColorObject) (if (or (and (setq CMS_TextStyle (cdr (assoc "TextStyle" CMS_Config))) (tblsearch "STYLE" CMS_TextStyle) ) (not (cdr (assoc "TextStyle" CMS_Config))) ) (progn (setq CMS_MLeaderStyles (vla-item (vla-get-Dictionaries (vla-get-ActiveDocument (vlax-get-acad-object))) "ACAD_MLEADERSTYLE")) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list CMS_MLeaderStyles CMS_NewName))) (progn (setq CMS_NewMLeaderStyle (vla-AddObject CMS_MLeaderStyles CMS_NewName "AcDbMLeaderStyle")) (if (not (cdr (assoc "TextStyle" CMS_Config))) (vla-put-TextStyle CMS_NewMLeaderStyle (getvar "TEXTSTYLE")) ) (foreach CMS_Item CMS_Config (if (and (vl-consp CMS_Item) (= (type (setq CMS_Property (car CMS_Item))) 'STR) (not (listp (cdr CMS_Item))) (vlax-property-available-p CMS_NewMLeaderStyle CMS_Property) ) (cond ( (wcmatch (strcase CMS_Property) "*COLOR*") (setq CMS_ColorObject (vlax-get-property CMS_NewMLeaderStyle CMS_Property)) (vla-put-ColorIndex CMS_ColorObject (cdr CMS_Item)) (vl-catch-all-apply 'vlax-put-property (list CMS_NewMLeaderStyle CMS_Property CMS_ColorObject)) ) ( T (vl-catch-all-apply 'vlax-put-property (list CMS_NewMLeaderStyle CMS_Property (cdr CMS_Item))) ) ) ) ) (princ (strcat "\n ** Created " CMS_NewName " MLeader style")) ) (princ "\n ** Error: MLeader style already exists") ) ) (princ "\n ** Error: textstyle does not exist") ) (princ) ) ;MLeaderLandingDistance (defun MLeaderLandingDistance ( sty flg / dic ) (and (setq dic (dictsearch (namedobjdict) "acad_mleaderstyle")) (setq dic (dictsearch (cdr (assoc -1 dic)) sty)) (entmod (subst (cons 43 ((if flg + -) (abs (cdr (assoc 43 dic))))) (assoc 43 dic) dic)) ) ) (defun c:MMN () (setq txt (tblsearch "style" "L-ARIAL") ) (if (null txt) (progn (command "_-style" "L-ARIAL" "Arial.ttf" "0.0" "1.0" "0" "" "") ) ) (CreateMLeaderStyle "L-TAG-TEXT" (list '("ArrowSize" . 2) '("ArrowSymbol" . "Dot") '("DoglegLength" . 3) '("LandingGap" . 1) '("LeaderLineColor" . 256) (cons "ScaleFactor" 1) '("TextColor" . 256) '("TextHeight" . 2) '("TextLeftAttachmentType" . 1) '("TextRightAttachmentType" . 1) '("TextStyle" . "L-ARIAL") ) ) (princ) (command "cmleaderstyle" "L-TAG-TEXT") ;;;;;;==================================== (MLeaderLandingDistance (getvar 'cmleaderstyle) nil) ) Quote
Dien nguyen Posted August 27, 2023 Author Posted August 27, 2023 (edited) I find another way to create multileader in lisp below, but how find another properties in multileader such as landing distance, color? (defun c:MM () (style "L-TAG-SHRUBS" 2) (MLeaderLandingDistance (getvar 'cmleaderstyle) t) ) (defun style (styleName asize) (setq txt (tblsearch "style" "L-ARIAL")) (if (null txt) (progn (command "_-style" "L-ARIAL" "Arial.ttf" "0.0" "1.0" "0" "" "") ) ) (setq newleaderstyle (vla-AddObject (vla-item (vla-get-Dictionaries (vla-get-ActiveDocument (vlax-get-acad-object))) "ACAD_MLEADERSTYLE") stylename "AcDbMLeaderStyle")) (vla-put-ArrowSymbol newleaderstyle "KL-ARRW") (vla-put-ArrowSize newleaderstyle asize) (vla-put-TextLeftAttachmentType newleaderstyle "1") (vla-put-TextRightAttachmentType newleaderstyle "1") (vla-put-TextStyle newleaderstyle "L-ARIAL") (vla-put-TextHeight newleaderstyle "2") (command "cmleaderstyle" styleName) ) Edited August 27, 2023 by Dien nguyen Quote
lido Posted August 27, 2023 Posted August 27, 2023 Try this: ;;Draw leader and text inside circle (DEFUN C:LEADBBL (/ *error* _Common _Getkword ACD BOX C67 CLA CTB DIA DIC DIS DMC DMH DMS DMY DSO FDS FIL LDI POS PT1 PT2 PT3 PTE PTW RAD RGT SRT TXT ) (defun *error* (s) (if (and PT2 (not PT3)) (redraw)) (if (and ACD DSO DMS) (vla-put-activedimstyle ACD (vla-item DIC DMS))) (if DIC (vlax-release-object DIC)) (if ACD (vlax-release-object ACD)) (or (wcmatch (strcase s) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\nError: " s))) (princ) ) (defun _Common (nume) (mapcar (function cons) (quote (0 100 67 410 8)) (list nume "AcDbEntity" C67 CTB CLA) ) ) (defun _Getkword (Ini Def Esc Msg / lies lopt noli stop) (prompt Msg) (setq lies (list (quote (2 13)) (quote (2 32))) Ini (mapcar (function (lambda (x) (list 2 (ascii x)))) Ini) ) (while (not stop) (setq noli (vl-catch-all-error-p (setq lopt (vl-catch-all-apply (function grread) (list nil 8)))) stop (cond ( noli Esc) ( (or (= (car lopt) 25) (vl-position lopt lies)) Def) ( (vl-position lopt Ini) (princ (chr (cadr lopt)))) ( T (if (= (car lopt) 2) (princ (chr (cadr lopt)))) (prompt (strcat "\nInvalid option." Msg))) ) ) ) (strcase stop) ) (setq CTB (if (= (getvar "CVPORT") 1) (getvar "CTAB") "Model") C67 (if (= CTB "Model") 0 1) CLA (getvar "CLAYER") DMS (getvar "DIMSTYLE") ACD (vla-get-activedocument (vlax-get-acad-object)) DIC (vla-get-dimstyles ACD) FIL (vl-filename-mktemp (substr (rtos (getvar "CDATE") 2 8) 10) nil ".tmp") ) (vlax-for itm DIC (setq LDI (cons (vla-get-name itm) LDI))) (setq LDI (acad_strlsort LDI)) (if (= (_Getkword (quote ("n" "N" "y" "Y")) "N" "N" (strcat "\nCurrent Dimension Style \"" DMS "\" settings will be used. Select another Dimension Style [Yes/No] <No>: ")) "Y") (if (setq FDS (open FIL "w")) (progn (write-line (strcat "DimStyle:dialog{label=\"Dimension Style selection\";initial_focus=\"Dims\";:row{:boxed_row{label=\"Available Dimension Styles\";:list_box{key=\"Dims\";height=8;width=" (itoa (+ (apply (function max) (mapcar (function strlen) LDI)) 2)) ";}}:column{alignment=bottom;fixed_height=true;:button{label=\"&OK\";key=\"DoIt\";is_default=true;width=14;fixed_width=true;height=2;}:spacer{height=0.25;}:button{label=\"&Cancel\";key=\"Cancel\";is_cancel=true;width=14;fixed_width=true;height=2;}}}}" ) FDS ) (setq FDS (close FDS) DIA (load_dialog FIL) POS (itoa (vl-position DMS LDI)) ) (new_dialog "DimStyle" DIA) (start_list "Dims") (foreach el LDI (add_list el)) (end_list) (set_tile "Dims" POS) (action_tile "Dims" "(setq POS $value)") (action_tile "DoIt" "(done_dialog 1)") (action_tile "Cancel" "(done_dialog 0)") (setq SRT (start_dialog)) (unload_dialog DIA) (vl-file-delete FIL) (if (and (= SRT 1) (/= (vl-position DMS LDI) (atoi POS))) (progn (setq DSO (nth (atoi POS) LDI)) (vla-put-activedimstyle ACD (vla-item DIC DSO)) ) ) ) (alert (strcat "Unable to write data to folder \"" (vl-filename-directory FIL) "\". Current Dimension Style \"" DMS "\" settings will be used.")) ) ) (setq DMC (getvar "DIMCLRD") DMH (getvar "DIMTXT") DMY (getvar "DIMTXSTY") ) (initget 1) (setq PT1 (getpoint "\nLeader start point: ")) (initget 1) (setq PT2 (getpoint PT1 "\nLeader second point: ")) (grdraw PT1 PT2 (if (vl-position DMC (quote (0 256))) (vla-get-color (vla-item (vla-get-layers ACD) CLA)) DMC)) (initget 1) (setq PT3 (getpoint PT2 "\nX coordinate of the Leader last point: ") DIS (distance PT2 (list (car PT3) (cadr PT2) (caddr PT2))) PTE (polar PT2 0 DIS) PTW (polar PT2 pi DIS) RGT (< (car PT2) (car PT3)) ) (redraw) (entmake (append (_Common "LEADER") (list (cons 62 DMC) (quote (100 . "AcDbLeader")) (cons 3 (cond (DSO) (DMS))) (cons 10 PT1) (cons 10 PT2) (cons 10 (if RGT PTE PTW)) ) ) ) (if (and (setq TXT (getstring T "\nAnnotation text: ")) (vl-remove 32 (vl-string->list TXT)) ) (progn (setq BOX (textbox (list (cons 1 TXT) (cons 7 DMY) (cons 40 DMH))) RAD (fix (+ 0.5 (max 0.5 (* 0.9 DMH) (* 0.525 (distance (car BOX) (cadr BOX)))))) PT1 (if RGT (polar PTE 0 RAD) (polar PTW pi RAD)) ) (entmake (append (_Common "CIRCLE") (list (cons 62 DMC) (quote (100 . "AcDbCircle")) (cons 10 PT1) (cons 40 RAD) ) ) ) (entmake (append (_Common "TEXT") (list (cons 62 (getvar "DIMCLRT")) (quote (100 . "AcDbText")) (cons 10 PT1) (cons 40 DMH) (cons 1 TXT) (quote (50 . 0.)) (cons 41 (vla-get-width (vla-item (vla-get-textstyles ACD) DMY))) (quote (51 . 0.)) (cons 7 DMY) (quote (71 . 0)) (quote (72 . 1)) (cons 11 PT1) (quote (73 . 2)) ) ) ) ) ) (if DSO (vla-put-activedimstyle ACD (vla-item DIC DMS))) (vlax-release-object DIC) (vlax-release-object ACD) (princ) ) ;;C:LEADBBL 2 Quote
