taybac213 Posted August 26, 2023 Posted August 26, 2023 Lisp 1(Lisp offsec Lee Mac): create 2 secment offset to the pline. Length secment =select 2 points on the pline Lisp 2(Lisp note): Create a note by selecting 2 points Please help to combine the 2 lisp above (Lisp 3): Lisp creates a notes secment by pick 2 points on the pline? OffsetSectionV1-1.lspFetching info... Lisp note.lspFetching info... Quote
Steven P Posted August 26, 2023 Posted August 26, 2023 (edited) Rather than combine the 2 I would be tempted to make a 3rd LISP that runs them in order. My preference since you can still use the 2 individual LISPs independently. So what to do: At the end of Lee Macs LISP, at the end of the main function and before the closing bracket - perhaps replacing the (princ) add something like: (list p q) this will return a list from this LISP I think, Point P1 and Point P2 In the note LISP replace the first line: c:2 ( p1 p2 / di nm a str hf p11) which now requires you to supply the 2 points before the LISP will run, finally make up the LISP to run them together: (defun c:test ( / alist e p1 p2) (setq alist (c:offsec)) (c:2 (nth 0 alist) (nth 1 alist)) (princ) ) Very much untested at the weekend Edited August 26, 2023 by Steven P Quote
taybac213 Posted August 26, 2023 Author Posted August 26, 2023 Thanh you @Steven P!II will try it right away Quote
taybac213 Posted August 26, 2023 Author Posted August 26, 2023 I don't want to bother you on the weekend!I'll ask you more next week!Thanks you! 1 Quote
BIGAL Posted August 26, 2023 Posted August 26, 2023 (edited) Sometimes it can be as simple as chain the correct sequence of commands, did not look very hard at code. Lots of code (c:offsec) (c:2) Edited August 26, 2023 by BIGAL 2 Quote
Steven P Posted August 26, 2023 Posted August 26, 2023 ahh., forgot, have to remove the get points part of the second lisp - will have a look next week, remind me 1 Quote
Steven P Posted August 28, 2023 Posted August 28, 2023 A couple of changes to make from the codes: This is Lee Macs with a return value at the end (the selected points) Refer to above or his website for the original version ;;------------------=={ Offset LWPolyline Section }==-------------------;; (defun c:offsec ( / d e h l m n o p q w x z ) (if (null *off*) (setq *off* 1.0) ) (initget 6) (if (setq d (getdist (strcat "\nSpecify Offset <" (rtos *off*) ">: ")));Chọn khoảng cách ofsset (setq *off* d) (setq d *off*) ) (while (progn (setvar 'errno 0) (setq e (car (entsel "\nSelect LWPolyline: ")));Chọn polyline (cond ( (= 7 (getvar 'errno)) (princ "\nMissed, try again.") ) ( (null e) nil) ( (/= "LWPOLYLINE" (cdr (assoc 0 (entget e)))) (princ "\nObject is not an LWPolyline.") ) ( (setq p (getpoint "\nSpecify 1st Point: ")) (setq p (vlax-curve-getclosestpointto e (trans p 1 0))) (while (and (setq q (getpoint (trans p 0 1) "\nSpecify 2nd Point: ")) (equal p (setq q (vlax-curve-getclosestpointto e (trans q 1 0))) 1e-8) ) (princ "\nPoints must be distinct.") ) (if q (progn (if (> (setq m (vlax-curve-getparamatpoint e p)) (setq n (vlax-curve-getparamatpoint e q)) ) (mapcar 'set '(m n p q) (list n m q p)) ) (setq e (entget e) h (reverse (member (assoc 39 e) (reverse e))) h (subst (cons 70 (logand (cdr (assoc 70 h)) (~ 1))) (assoc 70 h) h) l (LM:LWVertices e) z (assoc 210 e) ) (repeat (fix m) (setq l (cdr l)) ) (if (not (equal m (fix m) 1e-8)) (setq x (car l) w (cdr (assoc 40 x)) l (cons (list (cons 10 (trans p 0 (cdr z))) (cons 40 (+ w (* (- m (fix m)) (- (cdr (assoc 41 x)) w)))) (assoc 41 x) (cons 42 (tan (* (- (min n (1+ (fix m))) m) (atan (cdr (assoc 42 x))) ) ) ) ) (cdr l) ) ) ) (setq l (reverse l)) (repeat (+ (length l) (fix m) (- (fix n)) -1) (setq l (cdr l)) ) (if (not (equal n (fix n) 1e-8)) (setq x (car l) w (cdr (assoc 40 x)) l (vl-list* (list (cons 10 (trans q 0 (cdr z))) '(40 . 0.0) '(41 . 0.0) '(42 . 0.0) ) (list (assoc 10 x) (assoc 40 x) (cons 41 (+ w (* (/ (- n (max m (fix n))) (- (1+ (fix n)) (max m (fix n)))) (- (cdr (assoc 41 x)) w) ) ) ) (cons 42 (tan (* (if (< (fix n) m) 1.0 (- n (fix n))) (atan (cdr (assoc 42 x))) ) ) ) ) (cdr l) ) ) ) (setq o (vlax-ename->vla-object (entmakex (append h (apply 'append (reverse l)) (list z))) ) ) (vl-catch-all-apply 'vla-offset (list o d)) (vl-catch-all-apply 'vla-offset (list o (- d))) (vla-delete o) ) ) ) ) ) ) (princ) (list p q) ;;Addd this ) ;; Tangent - Lee Mac ;; Args: x - real (defun tan ( x ) (if (not (equal 0.0 (cos x) 1e-8)) (/ (sin x) (cos x)) ) ) ;; LW Vertices - Lee Mac ;; Returns a list of lists in which each sublist describes the position, ;; starting width, ending width and bulge of a vertex of an LWPolyline (defun LM:LWVertices ( e ) (if (setq e (member (assoc 10 e) e)) (cons (list (assoc 10 e) (assoc 40 e) (assoc 41 e) (assoc 42 e) ) (LM:LWVertices (cdr e)) ) ) ) ;;----------------------------------------------------------------------;; (vl-load-com) (princ (strcat "\n:: OffsetSection.lsp | Version 1.1 | \\U+00A9 Lee Mac " (menucmd "m=$(edtime,0,yyyy)") " www.lee-mac.com ::" "\n:: Type \"offsec\" to Invoke ::" ) ) (princ) ;;----------------------------------------------------------------------;; ;; End of File ;; ;;----------------------------------------------------------------------;; This is the notes LISP to accept 2 points as inputs, again refer to the above for the original ;https://www.theswamp.org/index.php?topic=54646.0 ;;(DEFUN c:2 (/ p1 p2 di nm a str hf p11) (DEFUN c:2 (p1 p2 / di nm a str hf p11) ;; changed this (IF (OR (NOT g:tarrow:hf) (NOT (NUMBERP g:tarrow:hf)) (NOT (> g:tarrow:hf 0.0))) (SETQ g:tarrow:hf 100.0) ) ; end if (INITGET 6) (SETQ hf (GETREAL (STRCAT "\n->Enter text height < " (RTOS g:tarrow:hf 2 2) " > : "))) ; FONT HEIGHT = altura da fonte (IF (> hf 0.0) (SETQ g:tarrow:hf hf) ) ; end if (setq txtstyle (getvar 'textstyle)) ;; (WHILE (SETQ p1 (GETPOINT "\n-> Click the first point :")) ; FIRST POINT = Give a first point ;; (IF (SETQ p2 (GETPOINT p1 "\r-> Click the next point : ")) ; SECOND POINT = Now give me a second point ;; (PROGN ; split this away from the setq line (SETQ di (/ (* g:tarrow:hf 0.45) 0.5) nm (TRANS '(0.0 0.0 1.0) 1 0 T) a (ANGLE p1 p2) str "" p11 (POLAR (POLAR p1 (ANGLE p1 p2) (/ (DISTANCE p1 p2) 2.0)) (- a (* PI 0.5)) (/ g:tarrow:hf 5.0)) ) ; end setq (ENTMAKE (LIST (CONS 0 "LWPOLYLINE") (CONS 100 "AcDbEntity") (CONS 100 "AcDbPolyline") (CONS 90 3) (CONS 70 0) (CONS 8 "Texto e Seta") ; Text and arrow (CONS 10 (TRANS p2 1 nm)) (CONS 40 0.0) (CONS 41 (/ di 2.0)) (CONS 62 21) (CONS 10 (TRANS (POLAR p2 (ANGLE p2 p1) di) 1 nm)) (CONS 10 (TRANS p1 1 nm)) (CONS 210 nm) ) ; end list ) ; end entmake (WHILE (AND (NOT (> (STRLEN str) 0)) (NOT (WCMATCH str "*#*@*")) (NOT (WCMATCH str "*@*#*"))) (setq default (vlax-ldata-get "DC-MWA" "str" "TNT-UPVC-D200")) (if (= "" (setq str (getstring T (strcat "\nEnter text note <" default ">: ")))) (setq str default) (vlax-ldata-put "DC-MWA" "str" str)) ) ; emd if (ENTMAKE (LIST (CONS 0 "TEXT") (CONS 100 "AcDbEntity") (CONS 100 "AcDbText") (CONS 7 txtstyle) (CONS 10 (LIST 2. 2. 2.)) (CONS 40 g:tarrow:hf) (CONS 41 0.6) (CONS 8 "Texto e Seta") ; Text and arrow (CONS 62 1) (CONS 1 str) (CONS 50 (IF (MINUSP (COS a)) (+ PI a) a ) ) (CONS 72 1) (CONS 11 (MAPCAR '(LAMBDA (X1 X2) (/ (+ X1 X2) 2.)) P1 P2)) (CONS 73 1) ) ; end list ) ; end entmake ;; ) ; end progn ;; ) ; end if ;; ) ; end while (PRINC) ) ;|«Visual LISP© Format Options» (140 2 40 2 nil "end of " 100 9 2 1 0 nil nil nil T) ;*** DO NOT add text below the comment! ***|; 1 Quote
taybac213 Posted August 28, 2023 Author Posted August 28, 2023 Thank you I have tried, can you help me fix it as shown below Quote
Steven P Posted August 28, 2023 Posted August 28, 2023 Should be easy enough... is there a set offset for the text and arrow or will it depend on the offset from Lee Macs code? 1 Quote
