Hatch True Color to layer
Dien nguyen
I'm trying to write a lisp to create a layer with color and name from an existing hatch and text, however I can't get the true hatch color to put in the layer color, here is my lisp, showing hatch -color is just the ACI color. How to get true color for hatch-color? And can hatch pick first.
(defun C:HN (/ obj hatch-name hatch-color new-layer)
	(setq sset (car (entsel)))
	(setq obj (vlax-ename->vla-object sset))
	(setq hatch-color (vla-get-color obj))
	(setq ent (entsel "Pick text"))
	(setq txt (cdr (assoc 1 (entget (car ent)))))
;	(createlayer test '(100 150 200) "Continuous" aclnwtbylwdefault)
	(createlayer txt hatch-color "Continuous" aclnwtbylwdefault)
	(command "chprop" sset "" "la" txt  "")
(defun createlayer ( name color linetype lineweight / lay tru )
    (setq lay (vla-add (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) name))
    (if (listp color)
            (setq tru (vla-get-truecolor lay))
            (apply 'vla-setrgb (cons tru color))
            (vla-put-truecolor lay tru)
        (vla-put-color lay color)
    (vla-put-linetype lay linetype)
    (vla-put-lineweight lay lineweight)
    lay
Have a look at this to create a true colour layer:
(createlayer "Layer" '(75 150 225) "Continuous" 0)
Noting that colour is a list of RGB variables, so all you need to search out is the conversion from what the hatch colour gives you that
You can get the hatch colour something like this
(defun c:getcolour ( / MyEnt MyColour)
  (setq MyEnt (entget (car (entsel "Select Entity"))))
  (if (= (assoc 420 MyEnt) nil)
    (setq MyColour (cdr (assoc 62 MyEnt)))
    (setq MyColour (cdr (assoc 420 MyEnt)))
  ) ; end if
  MyColour
then convert thrue colour to rgb
An AcCmColor object is independent of the entity (graphical/non-graphical) to which it applies; hence, you can skip the testing for colour type altogether:
(defun c:hn ( / e h n x )
    (if
        (and (setq h (car (entsel "\nSelect hatch: ")))
                (while
                    (and (setq e (car (entsel "\nSelect text: ")))
                        (not
                            (and
                                (= "TEXT" (cdr (assoc 0 (setq x (entget e)))))
                                (snvalid (setq n (cdr (assoc 1 x))))
                    (princ "\nText not valid for use as a layer name.")
                e
        (vla-put-truecolor
            (vla-add (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) n)
            (vla-get-truecolor (vlax-ename->vla-object h))
  • Like 2
