Dien nguyen Posted August 25, 2023 Share Posted August 25, 2023 I'm trying to write a lisp to create a layer with color and name from an existing hatch and text, however I can't get the true hatch color to put in the layer color, here is my lisp, showing hatch -color is just the ACI color. How to get true color for hatch-color? And can hatch pick first. (defun C:HN (/ obj hatch-name hatch-color new-layer) (setq sset (car (entsel))) (setq obj (vlax-ename->vla-object sset)) (setq hatch-color (vla-get-color obj)) (setq ent (entsel "Pick text")) (setq txt (cdr (assoc 1 (entget (car ent))))) ; (createlayer test '(100 150 200) "Continuous" aclnwtbylwdefault) (createlayer txt hatch-color "Continuous" aclnwtbylwdefault) (command "chprop" sset "" "la" txt "") ) (defun createlayer ( name color linetype lineweight / lay tru ) (setq lay (vla-add (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) name)) (if (listp color) (progn (setq tru (vla-get-truecolor lay)) (apply 'vla-setrgb (cons tru color)) (vla-put-truecolor lay tru) ) (vla-put-color lay color) ) (vla-put-linetype lay linetype) (vla-put-lineweight lay lineweight) lay ) Quote Link to comment Share on other sites More sharing options...
Steven P Posted August 25, 2023 Share Posted August 25, 2023 Have a look at this to create a true colour layer: (createlayer "Layer" '(75 150 225) "Continuous" 0) Noting that colour is a list of RGB variables, so all you need to search out is the conversion from what the hatch colour gives you that Quote Link to comment Share on other sites More sharing options...
Dien nguyen Posted August 25, 2023 Author Share Posted August 25, 2023 With specifies true color i can create layer with layer, but i want get hatch color to match layer color Quote Link to comment Share on other sites More sharing options...
Steven P Posted August 25, 2023 Share Posted August 25, 2023 You can get the hatch colour something like this (defun c:getcolour ( / MyEnt MyColour) (setq MyEnt (entget (car (entsel "Select Entity")))) (if (= (assoc 420 MyEnt) nil) (setq MyColour (cdr (assoc 62 MyEnt))) (setq MyColour (cdr (assoc 420 MyEnt))) ) ; end if MyColour ) then convert thrue colour to rgb 1 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 25, 2023 Share Posted August 25, 2023 An AcCmColor object is independent of the entity (graphical/non-graphical) to which it applies; hence, you can skip the testing for colour type altogether: (defun c:hn ( / e h n x ) (if (and (setq h (car (entsel "\nSelect hatch: "))) (progn (while (and (setq e (car (entsel "\nSelect text: "))) (not (and (= "TEXT" (cdr (assoc 0 (setq x (entget e))))) (snvalid (setq n (cdr (assoc 1 x)))) ) ) ) (princ "\nText not valid for use as a layer name.") ) e ) ) (vla-put-truecolor (vla-add (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) n) (vla-get-truecolor (vlax-ename->vla-object h)) ) ) (princ) ) 2 Quote Link to comment Share on other sites More sharing options...
Steven P Posted August 25, 2023 Share Posted August 25, 2023 Thanks Lee - I learn something every time you post! Quote Link to comment Share on other sites More sharing options...
Dien nguyen Posted August 25, 2023 Author Share Posted August 25, 2023 Thank Lee Mac, I'm happy to get your feedback, it works great, I used many of your lisp. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 25, 2023 Share Posted August 25, 2023 You're most welcome Quote Link to comment Share on other sites More sharing options...
