pmadhwal7 Posted August 27, 2023 Author Share Posted August 27, 2023 Anybody please help me Quote Link to comment Share on other sites More sharing options...
Tsuky Posted August 27, 2023 Share Posted August 27, 2023 Try this (defun c:test ( / ss1 ss2 ss n ename l1 l2 l) (defun string-subst (nam_obj new_string old_string / value_string nbs tmp_nbs) (setq value_string (vlax-get nam_obj 'TextString) nbs 0) (while nbs (if (setq nbs (vl-string-search old_string value_string (setq tmp_nbs nbs))) (setq value_string (vl-string-subst new_string old_string value_string tmp_nbs) nbs (1+ nbs) ) ) ) (vlax-put nam_obj 'TextString value_string) (vlax-put nam_obj 'Width 25.0) ) (setq ss1 (ssget "_X" '((0 . "MTEXT") (1 . "Cable length-*"))) ss2 (ssget "_X" '((0 . "MTEXT") (1 . "Pole to pole length-*"))) ss (ssadd) ) (cond ((and ss1 ss2) (repeat (setq n (sslength ss1)) (setq ename (ssname ss1 (setq n (1- n))) l1 (cons (cons ename (cdr (assoc 10 (entget ename)))) l1) ) ) (repeat (setq n (sslength ss2)) (setq ename (ssname ss2 (setq n (1- n))) l2 (cons (cons ename (cdr (assoc 10 (entget ename)))) l2) ) ) (setq l (vl-remove nil (mapcar '(lambda (z) (vl-remove nil z) ) (mapcar '(lambda (x) (mapcar '(lambda (y) (if (and (< (distance (cdr x) (cdr y)) 2.6) (> (distance (cdr x) (cdr y)) 2.5) ) (cons (car x) (car y)) ) ) l2 ) ) l1 ) ) ) ) (cond (l (foreach e (mapcar 'car l) (setq str1 (cdr (assoc 1 (entget (car e)))) str2 (strcat "\\P" (cdr (assoc 1 (entget (cdr e))))) ) (entdel (cdr e)) (string-subst (vlax-ename->vla-object (car e)) (strcat str1 str2) str1) (ssadd (car e) ss) ) (sssetfirst nil ss) ) ) ) ) ) Quote Link to comment Share on other sites More sharing options...
pmadhwal7 Posted August 28, 2023 Author Share Posted August 28, 2023 13 hours ago, Tsuky said: Try this (defun c:test ( / ss1 ss2 ss n ename l1 l2 l) (defun string-subst (nam_obj new_string old_string / value_string nbs tmp_nbs) (setq value_string (vlax-get nam_obj 'TextString) nbs 0) (while nbs (if (setq nbs (vl-string-search old_string value_string (setq tmp_nbs nbs))) (setq value_string (vl-string-subst new_string old_string value_string tmp_nbs) nbs (1+ nbs) ) ) ) (vlax-put nam_obj 'TextString value_string) (vlax-put nam_obj 'Width 25.0) ) (setq ss1 (ssget "_X" '((0 . "MTEXT") (1 . "Cable length-*"))) ss2 (ssget "_X" '((0 . "MTEXT") (1 . "Pole to pole length-*"))) ss (ssadd) ) (cond ((and ss1 ss2) (repeat (setq n (sslength ss1)) (setq ename (ssname ss1 (setq n (1- n))) l1 (cons (cons ename (cdr (assoc 10 (entget ename)))) l1) ) ) (repeat (setq n (sslength ss2)) (setq ename (ssname ss2 (setq n (1- n))) l2 (cons (cons ename (cdr (assoc 10 (entget ename)))) l2) ) ) (setq l (vl-remove nil (mapcar '(lambda (z) (vl-remove nil z) ) (mapcar '(lambda (x) (mapcar '(lambda (y) (if (and (< (distance (cdr x) (cdr y)) 2.6) (> (distance (cdr x) (cdr y)) 2.5) ) (cons (car x) (car y)) ) ) l2 ) ) l1 ) ) ) ) (cond (l (foreach e (mapcar 'car l) (setq str1 (cdr (assoc 1 (entget (car e)))) str2 (strcat "\\P" (cdr (assoc 1 (entget (cdr e))))) ) (entdel (cdr e)) (string-subst (vlax-ename->vla-object (car e)) (strcat str1 str2) str1) (ssadd (car e) ss) ) (sssetfirst nil ss) ) ) ) ) ) thanks very much this is what i need, but cna you tell me why this code not working on other dwgs i attached one more dwg please check thanks again new.dwg Quote Link to comment Share on other sites More sharing options...
Tsuky Posted August 28, 2023 Share Posted August 28, 2023 To also take the simple texts into consideration, this? But depending on whether we apply the code to another drawing, it may require a lot of adjustments: - Filter (ssget) with layers or others and the character string - Change search distances between text insertions (here 3.0 and 2.0) (defun c:test ( / ss1 ss2 ss n ename l1 l2 l) (defun string-subst (nam_obj new_string old_string / value_string nbs tmp_nbs) (setq value_string (vlax-get nam_obj 'TextString) nbs 0) (while nbs (if (setq nbs (vl-string-search old_string value_string (setq tmp_nbs nbs))) (setq value_string (vl-string-subst new_string old_string value_string tmp_nbs) nbs (1+ nbs) ) ) ) (vlax-put nam_obj 'TextString value_string) (vlax-put nam_obj 'Width 25.0) ) (setq ss1 (ssget "_X" '((0 . "*TEXT") (1 . "Cable length-*"))) ss2 (ssget "_X" '((0 . "*TEXT") (1 . "Pole to pole length-*"))) ss (ssadd) ) (cond ((and ss1 ss2) (repeat (setq n (sslength ss1)) (setq ename (ssname ss1 (setq n (1- n))) l1 (cons (cons ename (cdr (assoc 10 (entget ename)))) l1) ) ) (repeat (setq n (sslength ss2)) (setq ename (ssname ss2 (setq n (1- n))) l2 (cons (cons ename (cdr (assoc 10 (entget ename)))) l2) ) ) (setq l (vl-remove nil (mapcar '(lambda (z) (vl-remove nil z) ) (mapcar '(lambda (x) (mapcar '(lambda (y) (if (and (< (distance (cdr x) (cdr y)) 3.0) (> (distance (cdr x) (cdr y)) 2.0) ) (cons (car x) (car y)) ) ) l2 ) ) l1 ) ) ) ) (cond (l (foreach e (mapcar 'car l) (setq str1 (cdr (assoc 1 (entget (car e)))) str2 (strcat "\\P" (cdr (assoc 1 (entget (cdr e))))) ) (if (eq (cdr (assoc 0 (entget (car e)))) "TEXT") (progn (command "_.-MTEXT" (cdr (assoc 10 (entget (car e)))) "_Width" 25.0 str1 str2 "") (entdel (car e)) (entdel (cdr e)) (ssadd (entlast) ss) ) (progn (entdel (cdr e)) (string-subst (vlax-ename->vla-object (car e)) (strcat str1 str2) str1) (ssadd (car e) ss) ) ) ) (sssetfirst nil ss) ) ) ) ) ) Quote Link to comment Share on other sites More sharing options...
pmadhwal7 Posted August 30, 2023 Author Share Posted August 30, 2023 On 8/28/2023 at 1:42 PM, Tsuky said: To also take the simple texts into consideration, this? But depending on whether we apply the code to another drawing, it may require a lot of adjustments: - Filter (ssget) with layers or others and the character string - Change search distances between text insertions (here 3.0 and 2.0) (defun c:test ( / ss1 ss2 ss n ename l1 l2 l) (defun string-subst (nam_obj new_string old_string / value_string nbs tmp_nbs) (setq value_string (vlax-get nam_obj 'TextString) nbs 0) (while nbs (if (setq nbs (vl-string-search old_string value_string (setq tmp_nbs nbs))) (setq value_string (vl-string-subst new_string old_string value_string tmp_nbs) nbs (1+ nbs) ) ) ) (vlax-put nam_obj 'TextString value_string) (vlax-put nam_obj 'Width 25.0) ) (setq ss1 (ssget "_X" '((0 . "*TEXT") (1 . "Cable length-*"))) ss2 (ssget "_X" '((0 . "*TEXT") (1 . "Pole to pole length-*"))) ss (ssadd) ) (cond ((and ss1 ss2) (repeat (setq n (sslength ss1)) (setq ename (ssname ss1 (setq n (1- n))) l1 (cons (cons ename (cdr (assoc 10 (entget ename)))) l1) ) ) (repeat (setq n (sslength ss2)) (setq ename (ssname ss2 (setq n (1- n))) l2 (cons (cons ename (cdr (assoc 10 (entget ename)))) l2) ) ) (setq l (vl-remove nil (mapcar '(lambda (z) (vl-remove nil z) ) (mapcar '(lambda (x) (mapcar '(lambda (y) (if (and (< (distance (cdr x) (cdr y)) 3.0) (> (distance (cdr x) (cdr y)) 2.0) ) (cons (car x) (car y)) ) ) l2 ) ) l1 ) ) ) ) (cond (l (foreach e (mapcar 'car l) (setq str1 (cdr (assoc 1 (entget (car e)))) str2 (strcat "\\P" (cdr (assoc 1 (entget (cdr e))))) ) (if (eq (cdr (assoc 0 (entget (car e)))) "TEXT") (progn (command "_.-MTEXT" (cdr (assoc 10 (entget (car e)))) "_Width" 25.0 str1 str2 "") (entdel (car e)) (entdel (cdr e)) (ssadd (entlast) ss) ) (progn (entdel (cdr e)) (string-subst (vlax-ename->vla-object (car e)) (strcat str1 str2) str1) (ssadd (car e) ss) ) ) ) (sssetfirst nil ss) ) ) ) ) ) Still I was confused how we able to do in new file,can we make it simple as I will convert it into mtex and from "new pole" next paragraph will start,only this thing I am unable to do, when I convert it and change width factor this is not happening, Quote Link to comment Share on other sites More sharing options...
