hi
i am looking for lisp that shows length x width like this drawing
i have been looking for similar lisps but they are not working the way i want, can someone help me to create such a lisp
Drawing2.dwg
Did you Google ? Try "label pline sides Autocad lisp" big hint look for a version by Kent Cooper no need to write code.
On 8/19/2023 at 5:30 AM, Hải_Duy said:
hi
Kent Cooper   , thank you
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/length-and-width-of-rectangle-as-text/td-p/1369617
(Defun C:PLWH ; = PolyLine Width x Height [overall extent from bounding box]
   (/ plss n plobj LL UR delta)
(setvar "dimzin" 0)
  (if (setq plss (ssget '((0 . "*POLYLINE"))))
    (repeat (setq n (sslength plss))
      (setq plobj (vlax-ename->vla-object (ssname plss (setq n (1- n)))))
      (vla-getBoundingBox plobj 'minpt 'maxpt)
      (setq
        LL (vlax-safearray->list minpt)
        UR (vlax-safearray->list maxpt)
        delta (mapcar '- UR LL)
      ); setq
      (command "_.text" "_c" ; [spelling out "_center" is taken as Osnap call]
  "_none"
  (mapcar '/
    (mapcar '+ (vlax-safearray->list minpt) (vlax-safearray->list maxpt))
    '(2 2 2)
  ); mapcar
  "" 0 ; accept default height, rotation 0
  (strcat (rtos (car delta) 2 3) " x " (rtos (cadr delta) 2 3)); first line of Text
); command
    ); repeat
  ); if
); defun
(setvar "dimzin" 0)
      (setq
      ); setq
  "_none"
  (mapcar '/
    '(2 2 2)
  ); mapcar
); command
    ); repeat
  ); if
); defun
this is this lisp, i found it yesterday 👏
