aridzv Posted August 18, 2023 Posted August 18, 2023 (edited) Hi. I have a lisp that update blocks attributes. I'm trying to add an option to change the attribute visibility state, including *U blocks (as usual...) dynamic & parametric blocks - see block No. 4 in the sample drawing. in this code it makes the attribute to complitly disappear... (defun c:chatht15-1 ( / ta an bent bent2 pt lay tagname ss bname x att temp YN VSBL ) (vl-load-com) ;;(vlax-put-property x 'visible :vlax-false) (setq tagname "ORDER") (setq ss (ssget (list (cons 0 "INSERT")))) (setq ht (getreal "\nEnter text height<24>: ")) (if (= ht nil) (setq ht 24) ) (setq an (getreal "\nEnter Rotation<0>: ")) (if (= an nil) (setq an 0) ) (initget "YES NO") (if (null (setq VSBL (getkword "\nVisible [YES/NO] <NO>: "))) (vla-put-invisible att :vlax-false) ) (princ VSBL) (setq tagname (strcase (getstring "\nAttribute tag specification<ORDER>: "))) (if (= tagname "") (setq tagname "ORDER") ) (initget "Yes No") (if (null (setq YN (getkword "\nClear Attribute Value? [Yes/No] <No>: "))) (setq YN "No") ) (setq an (/ (* an pi) 180)) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname SS (setq x (- x 1) )))) (if (= (vla-get-hasattributes obj) :vlax-true) (foreach att (vlax-invoke obj 'getattributes) (if (= tagname (strcase (vla-get-tagstring att))) (progn (vla-put-Rotation att an) (vla-put-height att ht) (if (= (vlax-get-property att 'Backward) :vlax-true) (vlax-put-property att 'Backward :vlax-false) ) (if (= (vlax-get-property att 'UpsideDown) :vlax-true) (vlax-put-property att 'UpsideDown :vlax-false) ) (if (= YN "Yes") (vla-put-textstring att "") ) ;; (vlax-put-property att 'visible :vlax-false) (if (= VSBL "NO") (progn (vla-put-invisible att :vlax-false) (vla-put-invisible att :vlax-true) ;;(vlax-put-property att 'visible :vlax-false) ;;(vlax-put-property att 'visible :vlax-true) );;close progn );;close if );;close progn ) ) ) ) (princ) ) I also attached a sample drawing. Thanks, aridzv. Drawing1.dwg Edited August 19, 2023 by aridzv Quote
BIGAL Posted August 19, 2023 Posted August 19, 2023 You have no att when calling this (vla-put-invisible att :vlax-false) will error. needs to go after this (if (= tagname (strcase (vla-get-tagstring att))) I would look at a DCL as well much easier to have all the questions in front of you. Quote
aridzv Posted August 19, 2023 Author Posted August 19, 2023 (edited) Hi @BIGAL and thanks for your reply!! thanks for pointing the issue with the redundant (vla-put-invisible att :vlax-false) - fixed it and it led me to find some more issues that was fixed - the revised code attached here below. DCL is Way beyond my abilities for now... thanks again, aridzv. (defun c:chatht15 ( / ta an bent bent2 pt lay tagname ss bname x att temp YN VSBL ) (vl-load-com) (setq ss (ssget (list (cons 0 "INSERT")))) (setq ht (getreal "\nEnter text height<24>: ")) (if (= ht nil) (setq ht 24) ) (setq an (getreal "\nEnter Rotation<0>: ")) (if (= an nil) (setq an 0) ) (initget "YES NO") (setq VSBL (getkword "\nVisible [YES/NO] <NO>: ")) (if (= VSBL nil) (setq VSBL "NO") ) (setq tagname (strcase (getstring "\nAttribute tag specification<ORDER>: "))) (if (= tagname "") (setq tagname "ORDER") ) (initget "Yes No") (if (null (setq YN (getkword "\nClear Attribute Value? [Yes/No] <No>: "))) (setq YN "No") ) (setq an (/ (* an pi) 180)) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname SS (setq x (- x 1) )))) (if (= (vla-get-hasattributes obj) :vlax-true) (foreach att (vlax-invoke obj 'getattributes) (if (= tagname (strcase (vla-get-tagstring att))) (progn (vla-put-Rotation att an) (vla-put-height att ht) (if (= (vlax-get-property att 'Backward) :vlax-true) (vlax-put-property att 'Backward :vlax-false) ) (if (= (vlax-get-property att 'UpsideDown) :vlax-true) (vlax-put-property att 'UpsideDown :vlax-false) ) (if (= YN "Yes") (vla-put-textstring att "") ) ;;(vlax-put-property att 'visible :vlax-false) (if (= VSBL "NO") (vla-put-invisible att :vlax-true) (vla-put-invisible att :vlax-false) );;close if );;close progn );;close if );;close foreach );;close if );;close repeat (princ) ) Edited August 19, 2023 by aridzv Quote
BIGAL Posted August 19, 2023 Posted August 19, 2023 If I can find time will do the dcl added to my To Do list. I start with a picture of what I want. Just a side note working on a make dcl from objects. Quote
