LengthAreaField change option to select text
3dwannab
I was trying to modify the LeeMac LengthAreaFieldV1-4.lsp to select an existing object first as opposed to picking a point for a new text.
http://www.lee-mac.com/lengthfield.html
In Lines 289-294 I've change them to:
          ((= "Object" sel)
           (setq flg nil)
          ((= "Point" sel)
           (not (setq flg t))
Not sure how to do this.
Thanks in advance.
Edited by 3dwannab
Sorry, the lastest 1.4 version.
I asked because you mentioned my Align Text to Curve program in your post, which is unrelated to the Length & Area Field program.
To prompt for object first, add the following between lines 254 & 255:
(setq flg t)
Revert any other modifications you have made.
Edited by Lee Mac
Sorry, Lee. I have now modified the starting post to the correct .lsp file.
This works a treat. I very rarely found that I use the point option
