Explode (replace ?) Solid and Gradient Hatches
More importantly, I need them as dense color matching lines, so replacing them is just fine.
Solid is fairly straight forward, just replace with a line style hatch scaled to be nearly solid and match the color.
Tougher is matching the gradient hatching to the varying colors the same, my brain is drawing a blank on if that can be easily done.
Main problem is, I need these logos/designs as different vector types and solid and gradient hatches are just left out when importing/converting.
This is a fairly simple example. I currently have to redo them in Illustrator, Inkscape etc. and just have to eyeball match the colors.
I included a sample .dwg and a PNG of the AI Illustrator file I made of one of the logos.
Logo 072022.dwg
Hi SLW
This one works OK with LINEAR gradients, but for some reason, it doesn't match exactly the Cylindrical ones.
I tried various interpolation methods, but none seems accurate.
;Replace gradient Hatch with lines
;Stefan M - 12.08.2023
(defun c:gradline ( / *error* o ss i e a col1 col2 en l c x1 x2
                   c1 c2 rgb r m
;;;  (setq *error* (err))
  (setq o (vlax-3d-point 0.0 0.0 0.0))
  (or *spacing* (setq *spacing* 0.1))
  (or *del* (setq *del* "No"))
  (if
    (and
      (setq ss (ssget "_:L" '((0 . "HATCH") (450 . 1) (470 . "LINEAR,CYLINDER,INVCYLINDER"))))
        (initget 6)
        (setq *spacing*
          (cond
            ((getdist (strcat "\nSpecify line spacing <" (rtos *spacing*) ">: ")))
            (*spacing*)
        (initget "Yes No")
        (setq *del*
          (cond
            ((getkword (strcat "\nDelete original hatch [Yes/No] <" *del* ">: ")))
            (*del*)
      (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i))))
            a (vla-get-gradientangle e)
            col1 (vla-get-gradientcolor1 e)
            col2 (vla-get-gradientcolor2 e)
      (setq en (entlast) l nil)
      (setq c (vla-copy e))
      (vla-rotate c o (- a))
      (vla-getboundingbox c 'x1 'x2)
      (setq x1 (car (vlax-safearray->list x1))
            x2 (car (vlax-safearray->list x2))
      (if
        (> (- x2 x1) *spacing*)
          (vla-put-HatchObjectType c acHatchObject)
          (vla-setpattern c acHatchPatternTypeUserDefined "_USER")
          (vla-put-patternangle c (/ pi 2))
          (vla-put-patternscale c *spacing*)
          (setq c1 (mapcar '(lambda (p) (vlax-get col1 p)) '(red green blue))
                c2 (mapcar '(lambda (p) (vlax-get col2 p)) '(red green blue))
          (if
            (eq (vla-get-gradientname e) "INVCYLINDER")
            (mapcar 'set '(c1 c2) (list c2 c1))
          (vla-put-truecolor c col1)
          (command "_explode" (vlax-vla-object->ename c))
          (while
            (setq en (entnext en))
            (setq l (cons
                      (list
                        (car (vlax-curve-getstartpoint en))
                        (vlax-ename->vla-object en)
                      l
          (foreach x l
            (if
              (eq (vla-get-gradientname e) "LINEAR")
              (setq rgb
                (mapcar
                 '(lambda (c1 c2)
                    (fix (+ 0.5 c1 (/ (* (- c2 c1) (- (car x) x1)) (- x2 x1))))
                  c1 c2
                (setq r (/ (- x2 x1) 2.0)
                      m (/ (+ x2 x1) 2.0)
                      rgb (mapcar
                           '(lambda (c1 c2 / q u)
                              (setq q (abs (- m (car x)))
                                    u (atan (/ (sqrt (- (* r r) (* q q))) q))
                              (fix (+ 0.5 c1 (/ (* (- c2 c1) 2 u) pi)))
                            c1 c2
            (vla-setrgb col1 (car rgb) (cadr rgb) (caddr rgb))
            (vla-put-truecolor (cadr x) col1)
            (vla-rotate (cadr x) o a)
          (if (eq *del* "Yes") (vla-delete e))
;;;  (*error* nil)
  • Thanks 1
That looks great to me. I'll check it at work tomorrow.
Thanks!!
Hi SLW
Here is a better approximation of cylindrical gradients.
Don't ask what those numbers are. Long story.
I forgot to tell you, the spherical gradients family is ignored. That would be the challenge...
Also, there is a property of gradient, "Centered", which in your case is always true. If you change it to not centered, the gradient is shifted and that's another story for another day.
                   c1 c2 rgb r m q
  ;(setq *error* (err))
  (if
    (and
        (initget 6)
        (setq *spacing*
          (cond
            (*spacing*)
        (initget "Yes No")
        (setq *del*
          (cond
            (*del*)
      (if
          (if
          (while
            (setq l (cons
                      (list
                      l
          (foreach x l
            (if
              (setq rgb
                (mapcar
                 '(lambda (c1 c2)
                  c1 c2
                      m (/ (+ x2 x1) 2.0)
                      q (/ (- m (car x)) r)
                      rgb (mapcar
                           '(lambda (c1 c2)
                              (fix (+ 0.5 c1 (* (- c2 c1) (+ (* 0.2684 (expt q 4)) (* -1.2598 (expt q 2)) 0.9954))))
                            c1 c2
  ;(*error* nil)
Edited by Stefan BMR
edit
  • Thanks 1
Thank you very much!
These should do the trick.
That works very well.
I'll check it later on some different logos.
The file size is 1/4 the size of the .ai file. Very nice!!
problem has already been solved by the comments above,
but I tried changing png to 24bit bmp in Windows Painter
and using the bmp to polyline routine I wrote before.
(Input 255, 255, 255, 30% in exclusion color, keep true color)
left : true color, right : aci color for ctb
In this case, there is already a gradient hatch on the CAD
so there is no need to perform this additional process.
but this routine can be applied to any image and it doesn't matter what shape it is
Drawing2.dwg
  • Thanks 1
This instance was to convert vector files with gradient hatches.
I'll try it, I do sometimes need to get image files to vector.
Exactly what I had to do for the example here was, I got the logos approved, but what ever company (companies) they were using couldn't use a .dwg or image files, they needed .svg or .ai or similar. The .dwg and several image types all didn't look very accurate when converted to vector in Illustrator, I ended up printing to PDF, importing the PDF into Illustrator and it only needed a little extra work. This example is just a portion of the entire logo. The .svg was too large to email so they used the .ai, AFAIK it worked okay, though.
Basically, I get files so they can be used by companies to place logos, etc. on T-shirts, awards and other products (I think one similar to this was also used in a video).
I have no clue why those companies can't just use the image file, nor do I know why the "bought and paid for" logos didn't come to the company as a vector file ( I actually completely made this particular one with instructions from the person wanting it completely in AutoCAD), but alas, I am just the lowly draftsman, they even turned down my request for Illustrator and Photoshop, so I have to send the files home and work on them. I need to learn to tell them no, not my problem.
This particular one, the co-worker in charge of the project was particular in getting the shading spot on, so I had very little leeway in the results, and they needed to look the correct shades and colors when printed on paper. One of the posters they designed, the printing company messed up the colors and shading slightly on the first few.
So any AutoCAD solution works for me. I do have a program "Pixel Extractor" by Highflybird, it is useful at times.
Thank you!!
These both are working pretty well.
It may be a while before I can test the results of outputs to .ai, .svg, etc. fully, but so far they seem sufficient for my purposes, until someone moves the goal posts on me.
