MOVE TEXT AND MAKE AN ARROW FROM THE TEXT ORIGINAL POSITION TO ITS NEW POSITION
Hi
You can try this for move text to mleader
(vl-load-com)
(defun make_mlead (pt str lay / tmp ptlst arr nw_obj)
  (initget 9)
  (setq
    tmp (getpoint (trans pt 0 1) "\nLeader position: ")
    ptlst (append pt (polar pt (angle pt (trans tmp 1 0)) (distance pt (trans tmp 1 0))))
    arr (vlax-make-safearray vlax-vbdouble (cons 0 (- (length ptlst) 1)))
  (vlax-safearray-fill arr ptlst)
  (setq nw_obj (vla-addMLeader Space (vlax-make-variant arr) 0))
  (vla-put-contenttype nw_obj acMTextContent)
  (vla-put-textstring nw_obj str)
  (vla-put-layer nw_obj lay)
  (vla-put-ArrowheadSize nw_obj (* (getvar "TEXTSIZE") 0.5))
  (vla-put-TextHeight nw_obj (getvar "TEXTSIZE"))
  (if (> (car pt) (car (trans tmp 1 0)))
      (vla-SetDogLegDirection nw_obj 0 (vlax-3D-point '(-1.0 0.0 0.0)))
      (vla-put-TextJustify nw_obj acAttachmentPointMiddleRight)
      (vla-setLeaderLineVertices nw_obj 0 (vlax-make-variant arr))
    (vla-put-TextJustify nw_obj acAttachmentPointMiddleLeft)
  (vla-update nw_obj)
(vl-load-com)
(defun c:movetxt2leader ( / js htx AcDoc Space ent pt ss dxf_ent txt lay)
  (princ "\nSelect polyline.")
  (while (not (setq js (ssget "_+.:E:S" '((0 . "LWPOLYLINE"))))))
  (initget 6)
  (setq htx (getdist (getvar "VIEWCTR") (strcat "\nGive text size <" (rtos (getvar "TEXTSIZE")) ">: ")))
  (if htx (setvar "TEXTSIZE" htx))
  (setq
    AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
    Space
    (if (= 1 (getvar "CVPORT"))
      (vla-get-PaperSpace AcDoc)
      (vla-get-ModelSpace AcDoc)
  (vla-startundomark AcDoc)
  (setq ent (ssname js 0) pr -1)
  (redraw ent 3)
  (repeat (fix (vlax-curve-getEndParam ent))
    (setq
      pt (vlax-curve-GetPointAtParam ent (setq pr (1+ pr)))
      ss
      (ssget
        "_C"
        pt
        (mapcar '+ pt (list (getvar "PDSIZE") (getvar "PDSIZE") (getvar "PDSIZE")))
        '((0 . "TEXT"))
    (cond
      (ss
        (setq
          dxf_ent (entget (ssname ss 0))
          txt (cdr (assoc 1 dxf_ent))
          lay (cdr (assoc 8 dxf_ent))
        (make_mlead pt txt lay)
        (entdel (ssname ss 0))
  (redraw ent 4)
  (vla-regen AcDoc acactiveviewport)
  (vla-endundomark AcDoc)
  (prin1)
Edited by Tsuky
Update for ask : request this code accepts only text on ID layer
On 8/13/2023 at 12:41 PM, Tsuky said:
Hi
(vl-load-com)
(defun make_mlead (pt str / tmp ptlst arr nw_obj)
  (initget 9)
  (setq
  (vla-put-layer nw_obj "ID")
  (vla-update nw_obj)
(vl-load-com)
(defun c:movetxt2leader ( / js htx AcDoc Space ent pt ss txt)
  (initget 6)
  (setq
    Space
  (redraw ent 3)
    (setq
      ss
      (ssget
        "_C"
        pt
        '((0 . "TEXT") (8 . "ID"))
    (cond
      (ss
        (setq txt (cdr (assoc 1 (entget (ssname ss 0)))))
        (make_mlead pt txt)
  (redraw ent 4)
  (prin1)
Thanks a lot this is what I need. Also, a small request this code accepts only text on ID layer what if the objects are on multiple layers and I need the arrow on the same layer as the text. This is a request.
I have edited the previous code for your request
THANKS A LOT
Edited by CADWORKER
THANKS A LOT; is there any way to select the text which has to be relocated instead of all the texts on that line.
With a question for each?
(vl-load-com)
	(initget 9)
	(setq
	(vla-update nw_obj)
(vl-load-com)
	(initget 6)
	(setq
		Space
		(setq
			ss
			(ssget
				"_C"
				pt
				'((0 . "TEXT"))
		(cond
			(ss
				(setq
				(redraw (cdar dxf_ent) 3)
				(initget "Yes No")
				(if (eq (getkword "\nProcess? [Yes/No] <N>: ") "Yes")
					(progn (make_mlead pt txt lay) (redraw (cdar dxf_ent) 4) (entdel (ssname ss 0)))
	(prin1)
(vl-load-com)
	(initget 9)
	(setq
	(vla-update nw_obj)
(vl-load-com)
	(initget 6)
	(setq
		Space
		(setq
			ss
			(ssget
				"_C"
				pt
				'((0 . "TEXT"))
		(cond
			(ss
				(setq
				(initget "Yes No")
	(prin1)
yes, this is good and it is very much appreciated. Thank you. Intially my idea was to select the line and select a text and move to a new location with arrow and size change then select another. Anyways this is also good.
Hi,
I have made a code that is not perfect. what I does it move the text and draws an arrow from the text insertion point.
I need in this code is to
change the text height,
set the arrow to the layer of the text and an option for arrow size.
continuous selections of text after each relocation.
(Defun c:Tpx (/ IP IP2)
(setq txt (car (entsel "Pick Text"))); entity
(if txt
(setq elist (entget txt)); entity list
(setq IP (cdr (assoc 10 elist))); Insertion Point
); progn
); if
(setq IP2 (getpoint "\nPick Next point: "))
(command "move" txt "" ip IP2 "")
(command "_.leader" IP IP2 "_a" "" "_n"))
