3dwannab Posted August 2, 2023 Share Posted August 2, 2023 (edited) I use a dws file to check the standards of drawings. It doesn't check for inconsistent transparency of layers. Is there a way to check for this? You'd think it would be part of the Layers plug-in built into ACAD. Edited August 2, 2023 by 3dwannab Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 2, 2023 Share Posted August 2, 2023 You could try contacting Autodesk but don't hold your breath for a response. Otherwise write your own check, need a file layer name and transparency. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 3, 2023 Share Posted August 3, 2023 I ran across and saved this article a while ago, Get and set layer and entity transparency using LISP - AutoCAD DevBlog I do not recall testing it out though. A little misleading with the checker claiming it checks names and properties. Pre-standard checker days (and pre transparency?) when I worked where that was needed, we had LISPs, etc. to run through the drawings. Hopefully I provided some help for you. Quote Link to comment Share on other sites More sharing options...
3dwannab Posted August 4, 2023 Author Share Posted August 4, 2023 Thanks, guys. So these plugs can be LISP files? Where are they stored? I think AD won't bother. But it's strange how it's left out. We have hatch layers that require transparency such as grass and windows to name a couple and it would be good to check them to ensure they are the same across the board. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 4, 2023 Share Posted August 4, 2023 You can store them anywhere in a Support Path, load with acaddoc.lsp or manually. Use a Scripts and Batch to run on several drawings automagically. See Lee Mac's sight for some instructions. How to Run an AutoLISP Program | Lee Mac Programming An Introduction to Script Writing | Lee Mac Programming Never hurts to try, make a post at Autodesk forums and contact them, if enough need improvements, it could happen. Quote Link to comment Share on other sites More sharing options...
