This is just caution for those of you who would like to sort your lists of any kind. If you're dealing with integers in your compare function, vl-sort will ruin your list.
I have a very simple test case for this. Suppose:
(setq lst '(0 0 0 1 0 0 0))
And you want to sort this list such that:
sort-list = (0 0 0 0 0 0 1)
You think you would use a simple implementation of vl-sort like the following:
(setq sort-list (vl-sort lst '(lambda (s1 s2) (<= s1 s2))))
It seems alright and you even considered that two values might be the same. So, fine and dandy, right? WRONG
What this will show is that:
sort-list = (0 1)
Now you lost information.
Now, you might be working with a list of entity names and you use the compare function.
'(lambda (s1 s2) (<= 	(atoi (LM:vl-getattributevalue (vlax-ename->vla-object s1) "ITEM_NO")
			(atoi (LM:vl-getattributevalue (vlax-ename->vla-object s2) "ITEM_NO")))
How will you be able to know that it didn't just skip or remove a block from your sorted list. Should you even trust this function? *end of rant*
You'd have to use something like what Kent1Cooper on the AutoCAD forums posted:
(mapcar 'cdr (vl-sort (mapcar '(lambda (x) (cons 1 x)) lst) '(lambda (y z) (< (cdr y) (cdr z)))))
Using Vl-sort need to take into account type of items in list strings, real and integers, or combinations. So theVL-sort is slightly different.
You can sort a list to multiple depths I have some code taht looks at up to the first 5 items in a list used with extract quantities.
;x only
(setq lst (vl-sort lst '(lambda (x y) (< (car x)(car y)))))
(vl-sort '(3 2 1 20 98.32 16 0 20 -2.345) '<)
(-2.345 0 1 2 3 16 20 98.32) only 1 20
(setq test '(87 6.54 20 1 8.88 20))   ; contains two 20's
(mapcar 'cdr (vl-sort (mapcar '(lambda (x) (cons 1 x)) test) '(lambda (y z) (< (cdr y) (cdr z)))))
returns:
(1 6.54 8.88 20 20 87); both 20's still there
; sorts on 1st two items
(vl-sort lst
	 '(lambda (a b)
	    (cond
	      ((< (car a) (car b)))
	      ((= (car a) (car b)) (< (cadr a) (cadr b)))
  • Agree 1
(mapcar '(lambda ( x ) (nth x lst)) (vl-sort-i lst '<))
Iterative version :
(defun _vl-sort ( l f / *q* ll ff gg )
  (if (= (type f) 'sym)
    (setq f (eval f))
  (while (setq *q* (car l))
    (setq ll
      (if (null ll)
        (cons *q* ll)
        (cond
          ( (apply f (list (last ll) *q*))
            (append ll (list *q*))
          ( (apply f (list *q* (car ll)))
            (cons *q* ll)
          ( t
            (setq ff nil)
            (setq gg (apply (function append)
              (append (mapcar (function (lambda ( *xxx* *yyy* )
                (if (null ff)
                  (if (apply f (list *q* *yyy*))
                    (progn (setq ff t) (list *xxx* *q*))
                    (list *xxx*)
                  (list *xxx*)
              )) ll (cdr ll)
              ) (list (list (last ll)))
            (if (null ff)
              gg
    (setq l (cdr l))
  ll
HTH., M.R.
Edited by marko_ribar
