Ajmal Posted July 29, 2023 Posted July 29, 2023 if I press enter without typing anything why getting "nil" actually, if I need to set the same value showing what there showing what i must do??? (if (null tmp) (setq tmp 25)) (initget 6) (and (setq tmp (getreal (strcat "\nSpecify the psize <" (vl-princ-to-string tmp)"> : "))) (setq psize tmp)) Quote
Ajmal Posted July 29, 2023 Author Posted July 29, 2023 How can i set if there is already an value. with out typing just pressing enter or space set the same vale Quote
marko_ribar Posted July 29, 2023 Posted July 29, 2023 (if (null tmp) (setq tmp 25)) (initget 6) (and (setq tmp (cond ( (getreal (strcat "\nSpecify the psize <" (vl-princ-to-string tmp)"> : ") ) ( tmp ) )) (setq psize tmp)) 1 1 1 Quote
BIGAL Posted July 30, 2023 Posted July 30, 2023 (edited) Another (if (null psize)(setq psize 25.0)) (setq tmp (getreal (strcat "\nSpecify the psize <" (rtos psize 2 2) "> : "))) (if (null tmp)(princ)) You can use my Multigetvals can save the last value for re-use. The initget has advantage of forcing a number. Edited July 30, 2023 by BIGAL 1 Quote
Ajmal Posted July 30, 2023 Author Posted July 30, 2023 16 hours ago, marko_ribar said: (if (null tmp) (setq tmp 25)) (initget 6) (and (setq tmp (cond ( (getreal (strcat "\nSpecify the psize <" (vl-princ-to-string tmp)"> : ") ) ( tmp ) )) (setq psize tmp)) Error: bad function: 25 (if (null tmp) (setq tmp 25)) (initget 6) (and (setq tmp (cond ( (getreal (strcat "\nSpecify the pipe size <" (vl-princ-to-string tmp)"> : ")) ( tmp )))) (setq pipesize tmp)) (setq dia (/ pipesize 2.0) start 0) Quote
Tsuky Posted July 30, 2023 Posted July 30, 2023 (if (zerop (getvar "USERR1")) (setvar "USERR1" 25.0) ) (initget 6) (setq pipesize (getreal (strcat "\nSpecify the pipesize <" (vl-princ-to-string (getvar "USERR1"))"> : "))) (if (not pipesize) (setq pipesize (getvar "USERR1")) (setvar "USERR1" pipesize)) 1 Quote
BIGAL Posted July 30, 2023 Posted July 30, 2023 Tsuky as USERR1 is a variable any code can get at and change I have started using LDATA it resides in the dwg, you provide the container name and a key then value. (vlax-ldata-put "AlanH" "Ahscale" 100) (setq ahsc (vlax-ldata-get "AlanH" "Ahscale")) (setq layname (vlax-ldata-get "AlanH" "Layoutname" ) ) Quote
